SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
SOURCE: ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
The exit sensor and
the duplex sensor
detect a paper jam 3
times in succession
Paper jams can occur for the following
reasons.
???? Dampness
???? Paper curl
???? Incorrect paper setting in the paper
tray
???? Stripper pawls coming apart
