What is the error code mean for flashing eight times on a KLV-40V300A LCD TV
8 blinks in KLV-32S400A shows Audio Error would this be the same for my KLV-40V300A? If so would I also need to replace the G3 power board? Thanks in advance.
I unhooked all the audio accessaries and it still has the same eight red flashes.I unhooked all the audio accessaries and it still has the same eight red flashes.
You can't post conmments that contain an email address.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
A short circuit with its main board component, can make 8 blinks of standby/power light. These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. http://electronicshelponline.blogspot.com/
8 blinks in KLV-32S400A shows Audio Error Check audio voltage supply from power supply board, if OK, replace GP Board (main board) and if audio volts are not available, check/ replace power supply board.
Eight blinks means, "High voltage error". The probable cause location
listed is "T8005 is faulty (D board). T8005 is the fly-back
transformer (FBT). or you can replace the full d-board
You may purchase the D board complete for $185.10
