A few days ago I was playing on my xbox 360 online with friends using a wireless connection using my Linksys WRT54G router and all of a sudden xbox live disconnected. I right away checked if my internet was still working and it was working fine. I checked if there was a problem with just my routers wireless and turned on my laptop and was able to connect wirelessly with that. I then tried connecting my router directly to my xbox 360 using a ethernet cable and it still wont connect to xbox live. My xbox will give me several different errors.
1. Your router or ISP may be blocking access to Xbox Live
2. Your network doesn't have a sufficient MTU setting. Xbox Live requires a minimun MTU setting of 1364.
Now, I went on my routers setup page and my MTU setting was automatic but I changed it to 1364 just to check, I also set it to 1500 as well, and still, no able to connect. I also checked if the ports were still unblocked on my router and they were. I don't know what else it can be. I have been playing on xbox live for a while with the setup I currently have and all of a sudden it just stopped working. Any suggestions?
Set up your Xbox Live connection by connecting your Xbox 360 to high-speed Internet. There are two options: connecting it to your network via Ethernet cable or connecting to your network via a wireless adapter. The simplest and fastest connection is connecting via Ethernet cable directly to your modem or router. If you must connect wirelessly, use the Xbox 360 wireless adapter, sold separately. See the Resources section below for connection tips.
Test your Xbox Live connection after connecting your Xbox 360 to your high-speed Internet. Navigate to the dashboard, select "My Xbox," choose "System Settings" then "Network Settings." Run the diagnostic test to confirm your connection works. Your Xbox 360 will offer troubleshooting tips if the test fails.
Create an Xbox Live gold account. Log out of all profiles then press the "Guide" button and choose "Join Xbox Live." Follow the prompts, entering your billing and personal information. You will also choose your gamertag during this process, which will serve as your online name and identity. Lastly, you will customize your profile. Your Xbox 360 will then create the account.
Insert your Xbox Live multiplayer game and open the game's Xbox Live multiplayer menu. Different games have different options but certain features remain the same across all multiplayer games. There is the TrueSkill ranked matchmaking system, which pits you against players of similar skill levels. There are also unranked player matches, where you can practice and hone your skills in a non-competitive atmosphere. Lastly, there is the quickmatch matchmaking system, which automatically searches for games for you, whether they are unranked or ranked.
Add and play with friends. Xbox Live allows users to add up to 100 friends. Add a friend by pressing the "Guide" button, navigating to the "Friends" tab, then selecting "Add Friend." Type in your friend's gamertag then press the "Start" button and choose "Send Friend Request." Your friend will need to confirm the request to complete the process. You can play multiplayer games with friends by opening your friends list and inviting them to a game lobby.
Communicate with friends and opponents using an Xbox 360 headset. The wired Xbox 360 plugs into your controller. Once it's plugged in, you can speak into microphone and listen to others from the ear piece.
I have the same problem. It does connect sometimes but once the Xbox is powered off and back on it is hit and miss whether it will connect to XBOX Live again. Recycling power on the router will sometimes work. There is no problem with general network or internet connections only problem is Xbox Live. I am using hardwired connection.
here is a website to help you setup the Xbox Live:
http://support.xbox.com/support/en/us/xb...
For more solution dial toll-free number 1 833 283 8333 and get instant solution and if the customer wants to move any kind of technical solution to our technical expert website and get all solution.
https://servicenumber.org/apple-routers....
