Vodafone 360 Logo
Anonymous Posted on Oct 05, 2012
Samsung vodafone h1 charging problems
Normal charger is not charge my mobile phone
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 06, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
2117
Points
19
1helpful
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 • Cell Phones
Samsung S3370 charging problem
Hello"":":
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Samsung T582G wont charge
Dear brother:
First Option:
Second Option:
The phone sometimes would not charge
First Option:
Second Option:
Aug 08, 2012 • Cell Phones
1helpful
2answers
While charging mobile restarts again and again
First Option:
Second Option:
7helpful
My samsung gravity 3 won'ty charge in car
This problem cannot be fixed. You'd have to return your Gravity 3 and exchange it for another model. It's a known problem with Samsung and should acknowledge it and recall this product (or fix it with a software update free of charge). I spent a whole day at different T-Mobile stores and finally a rep showed me the technical bulletin on it and exchanged the phone.
2helpful
Hiya i baught yesterday the vodafone samsung h1
change your sim through vodaphone store
My samsung cell phone gives no indication when charging so I donot know whether is charged or not.The problem is the charger or the mobile phone?It indicates only the bar which requires charging but when I...
There are 3 solutions to your problem.
1) You need to replace your phone's battery, or
2) You need to replace your charger. (If you have a car charger, try it to determine if your home charger is the problem) or
3) you need to have the charging plug on your phone repaired; it will need to be sent in for service.
Samsung D900 Mobile Phone
May be the phone was water damaged. This kind of problems normally we see in water damaged phones. If not water damaged then PA (Power Amplifier) may be shorted and need to be changed.
Charge problems
well you should take the phone and have it service from a mobile service center , my guess is the charger port may just need to be cleaned out.
Top Vodafone Facebook Apps Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Vodafone Facebook App Expert? Answer questions, earn points and help others
