Insignia 37" LCD Flat-Panel HDTV Logo
Posted on Oct 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv scanning through channels by itself - Insignia 37" LCD Flat-Panel HDTV
Level 3:
Top Expert:
  • Insignia Master 76,851 Answers
  • Posted on Oct 06, 2012
Insignia Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15001298
Points
237762
Check and replace the main system memory IC. Before replacing it, try a hard rest first. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset. It this do not help you, replace the above said IC.
How do I tune my teac led/lcd digital tv model no:le32a321 without a remote
Here are some steps to tune a Teac LED/LCD digital TV without a remote:
  1. Find the TV's on-screen menu buttons on the TV itself (often located on the side or bottom of the TV)
  2. Use the arrow buttons to navigate to the channel setup or tuning menu
  3. Select "Auto Tuning" or "Channel Scan" and follow the on-screen instructions to scan for available channels
  4. If the TV has manual tuning option, select it and input the frequency, symbol rate, and other information for each channel you want to add manually.
  5. Once the tuning process is complete, the TV should display all the available channels. If you are unable to access the menu without a remote, consider using a universal remote that is compatible with your TV or obtaining a replacement remote from the manufacturer.
Manual fir a sylvanian #lc321ss9 made in 2009
ManualsLib has the manual for the Sylvania LC321SS9 here: https://www.manualslib.com/manual/500307/Sylvania-Lc321ss9.html . See https://www.manualslib.com/manual/500307/Sylvania-Lc321ss9.html?page=18#manual for the directions for manual scanning of channels. If the TV looses power before you turn the TV off with the power button, the scanned channels will not be saved.
I hope this helps.
(Note: some TVs will delete digital channels from the stored channels if the signal strength consistently is too low for the tuner to interpret.)
If there is no channels after scanning is it the outside antenna?
Do you see any channels [as a glimpse], during auto-tune. If you see them for a moment during channel auto scan, and do not store them in the TV memory, after the channel scan has been finished; the fault is with the TV itself. If you do not see that glimpse of programs during channel auto scan, there are two possibilities.
1. The tuner of the set is faulty.
2. The set do not get any signal to process [might be antenna].
When i turn my tv on it shows do not power off scan, so i cannot view any channels
It's just trying to set itself up by scanning to see what available channels are present. You should be able to let it finish and then your TV will be programmed to only tune the channels you can actually receive.
This can sometimes take 10-15 minutes so be patient.
Connecting to basic cable
I just bought an RCA TV and was ready to throw it out the window. Spent 2 days trying to set it up asking RCA 5 times for help and went online and still couldn't solve my problem.
If you are connecting your TV to a cable box, your channels are already there so you do not have to scan for channels.
I recently got a basic cable plan but am only getting a couple of channels.. How can I change this?
The best thing to do is contact the cable provider and ask them to provide a list of the channels you are suppose to get. With all the channel mapping and digital TV display devices these days, you might need to have your display device scan for channels if the signal is not tuned through the cable box itself. The channels may be there but the tuner in the TV device has not scanned the channels to register them into it's memory. Also make sure to set the TV for a Cable mode of tuner.
1helpful
2answers
I have a Olevia 532-H that I am unable to scan under the channel set up.
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Vizio 32lcd turns itself off on certain station
Do a full channel scan again. It should solve that problem.
4helpful
4answers
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
My LXI TV won't allow me to get any channels above 13 after doing the auto scan for channels. I am using DirectTV.
The only way to fix the problem is to hook your TV to a standard cable hookup and go through the "auto memo" scan process. The auto scan progarm then automatically sets itself to the CATV mode, rather than the standard mode, so channels above 13 can be received after disconnecting and reconnecting to a DirectTV, satellite antenna.
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
