Hi there
I am having trouble connecting my Viewty to my PC. I followed the intructions given, installed the software and connected the phone via usb.The LG PC Suite says 'U990 Ready' after i follow the connection wizard.
When I try to syncronize my phone with the pc and ACTUALLY connect it says:
Initialize connection with MS Outlook (I)
Synchronisation failed.
Fail to connect to the phone,
Please check the COM port and connect in idle screen.
This also happens when i try to connect it to the Music Manager. The phone reads
'Cannot Execute. Conflict with (Startup Wizard)'
I have tried everything i can think of (which is little). I wondered if you could help.
My computer is not a new one. Do you think it is incompatible? It has Windows XP so i assumed it would be ok.
Thanks.
im tryin to get sum musicon my phone but everytime i try to sync it gives me this problem
Contacts : Synchronise ( MS Outlook )
Calendars : Synchronise ( MS Outlook )
Todo : Synchronise ( MS Outlook )
Memo : Synchronise ( MS Outlook )
can anyone help pliz
I had the same problem. It was caused by the phone waiting for the date to be entered (even though it was already done). To get over the problem click on the multitask icon on the phone (top right). If anything is running other than "Home Screen" and "Menu" click on the application and close it. PC synchronisation should strat to work now.
Hi
I have the exact same problem and its driving me mad I have spent nearly the whole day trying to sort this out , its driving me insane I have tried it in several different usb ports and still nothing, please help?
HELP! I tried that but it only says Home Screen and Menu, nothing else. I'm getting the same error message:
same prob..but when i tried closing the multitaskin it still wont work
Question 1 - If you open the task manager on the phone is the 'Startup wizard' program listed there?
Question 2 - If ever I want to manage the music on my phone I just use the USB cable with the phone in 'Mass storage' mode & use it like any other thumb-drive. It's much simpler & faster than the PC Suite route. Could you not do it this way?
Regards.
