What is the exact model number of your Panasonic TV? Visit the site named 'Electro-help' for
more details. Click this link. View it in
'Flip card' option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 900 posts to different brand TVs now.
If you do not get any solution by this site too, inform me by Fixya. I'll try to help you. OK?
SOURCE: Red light flashing. TV wont start.
Bypass the SEINE module if you know how. If you use off air HD you will have to get a new module.
SOURCE: Red light flashing, no picture/sound!!!!
HI, this unit has 3 main fuse links on the main board that may be blown. the fuse links should be check before you move further into the diagnosis stage. once you have checked the fuses and they are still in a working state, this will confirm a power supply board failure. this board provides and regulates the current flow and distribution of it throughout the entire unit. If the fuses are fine and the power supply board is damaged, the green light will come on briefly then, the main control will notice that the power supply is not functioning properly. Once the main control board senses an abnormal current, it will shut down the TV rendering the red light warning. The list of fuses to check are below. Remember, if they are fine and working, the issue will be the power supply board itself and, it will need to be replaced.
FUSE CHECK LIST--
3A 12v- fuse----(242208600623)
SM 3A 125v-fuse----(242208600657)
500 MA-fuse-----(242208611092)
PART NUMBER FOR POWER SUPPLY BOARD
(996500036816)
Please rate and god bless:)
SOURCE: black screen red light flashing, i unplugged the
Yes,usually there's two particular capacitors,maybe even 3. If not,then I would go with a Y Main Board since the tv will give error codes if the Y Buffer uper and lower boards have no power and therefore cause no picture,sound,and an error code.
SOURCE: my plasma tv has a red light flashing on the
You have to bad compacitors on the power board. They will be buldged on the top. Once replace you TV will live again. The parts will cost you about $4
SOURCE: tv went off and wont come back on. flashing 10 red
no voltage to tunner, change P.A board fix problem
