I do not have a remote to the tv and cannot change the input.
SOURCE: sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
SOURCE: How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
SOURCE: Sony remote RM-DX500 not working with Disc
There are 2 set's of command switch's for the dvd player, a 3 position command switch on the back side of the dvd player and another 3 position command switch on the inside of the remote right next to the batteries, easiest option is to remove batteries from remote and test each one of the 3 position switch's labeled 1,2 & 3 and test remote control.
