KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
Anonymous Posted on Dec 30, 2008
Blade won't release from mixer
Kitchen Aid model KSSWH stand mixer, lift up type. I have tried WD-40, hot water, tapping with a hammer etc., all to no avail.
  • Anonymous Dec 30, 2008
    Thanks for trying to help. I have used boiling water to try and "melt' any food the might be in there, I have removed the bottom plate so that I could 'tap" the blade (paddle) with a hammer etc. etc. I'm wondering if there may be a safety mechanism that is holding the blade in place.
Dave Kuper
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 14, 2015
Dave Kuper
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1050
Points
My Kitchenaid 6000HD mixer had the flat beater blade stuck onto the turning drive-shaft and would not move up, down, or sideways - like it was tack welded onto the drive-shaft. I tried all the initial recommended steps: oil-soak, hot towels, pouring boiling hot water, etc, - No Joy.
For final success I used a hot air gun - (a hair dryer would probably work) - to heat the socket of the blade where the pin (on the drive-shaft) inserts into the socket of the blade and (when the blade is turned) locks the blade onto the drive-shaft. I then used a small (craft-sized) rubber mallet to tap the outside of the blade socket all around and gripped the bottom of the blade (use a paper towel to guard your fingers from the heat) to turn the blade on the shaft slightly back and forth until it finally turned far enough to allow the pin to mate to the groove inside the blade socket. Then I tapped the top of the blade until the blade slid off.
After everything cooled to room temperature, I used a brass .45 caliber bore brush to thoroughly clean the inside of the blade socket paying special attention to the drive-shaft pin-grooves inside the socket. When cleaned, I then ran the hottest tap water into the socket for a few minutes and then dripped in Dawn dishwashing liquid to soak inside of the socket. I used a cloth with Dawn dishwashing liquid to thoroughly clean the drive-shaft.
I thoroughly rinsed and dried everything and using Olive Oil on my fingers, I lubricated the drive-shaft and pin. I carefully reinserted the blade onto the drive-shaft making sure to check that the blade was not sticking at any point on the shaft. It slid on and off several times with ease.
I then re-mounted the mixing bowl and affixed the blade onto the shaft. I made sure the mixer switch was turned to the OFF position, plugged the machine into power, and carefully turned the machine ON to the lowest setting to verify that the drive shaft was not bent and that the beater blade was undamaged. The machine turned the beater inside the bowl and ran like new.
I recommend that every time you use your mixer, that you use hot water and oil-dissolving dishwashing soap to ensure the inside of the mixer blade socket is clean; and that you thoroughly clean the drive-shaft and pin to ensure no food particles or other material remains on the shaft. Always use a little Olive or Vegetable oil to lubricate the shaft and verify that the blade can be moved onto and off the drive-shaft without sticking before storing the mixer for next use.
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Dec 30, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2173468
Points
14133
To Remove Flat Beater, Wire Whip or Dough Hook
1.
Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft.
If the beaters are stored on the shaft of the mixer when not in use, food traces can harden and make mixer attachments difficult to remove. Should this occur, wrap a hot, damp towel around the shaft to heat and expand the area. A small amount of cooking oil sprayed around the shaft may also help. After the beater has been removed, thoroughly clean the beater shaft area with a small brush to remove any food residue.
-Tha Mp3 Doctor
Anonymous
Level 2:
Scholar:
  • Expert 140 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
140
Questions
Helped
73276
Points
463
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Lift bowl kitchen aid mixer head wobble
what model, there are two different types. post 2002 and pre 2002. need more info
Kitchen aid stand mixer blades do not reach bottom of bowl
go to youtube type in ajustment on kitchen aids and it will show u step by step hope this helps
1helpful
I have been trying to remove the pin on my Kitchen Aid Classic Mixer to allow me to get inside the head and change the grease. The pin will not come out no matter what I do. I have tried spraying it with...
To remove a pin from a shaft, you really need a small steel hammer and
a pin punch. I purchased a set of three pin punches at Walmart for 4 dollars.
That's the only and proper way to remove the pin.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Make sure you have the shaft supported on a wooden block before
driving out the pin.
Can't attach ice cream maker dasher
If the bolt is the hinge pin that the head swivels on when tilting it up, it can be pushed back in when the head latch is released and the mixer head is lifted slightly.
Kitchen aid--heavy duty mixer
The beater is held in place by a pin and spring arrangement. Lift and twist the beater. If that doesn't work, the pin is trying to come out...and is wedging against the beater. Tap the pin back in a bit, and the beater should release.
Regards, --W/D--
Mixing attachment for stand mixer is stuck
I had this happen today. I took a towel and covered all of the beater except where it attaches. I sprayed WD-40 on it. This loosened it and it came unstuck. Then I washed it thoroughly with hot water and soap. It had some dried batter stuck inside which caused it to stick. Guess I better pay better attention to how clean I get it inside. PS Don't spray WD-40 anywhere else - this is something you make food with!
31helpful
7answers
Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Stuck blade
the spring is stuck in the release pin. usually wrapping it in a hot steamy towel for a while works. but what you might try is also wrapping it in a hot steamy towel for a frew min about 15-20 then taking a screw driver and lightly tap around the outside edge with the handle. do not hit hard like a hammer just light taps all the way around and that may help loosen the spring.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
