Lands Phones Logo
Posted on Oct 07, 2012
How to disable camera sound on alcatel - Alcatel Lands Phones
tip
ALCATEL CODE
For E Series:
Next codes work on alcatel E Series...
*#8273*# - Network Services
###847# - General reset
*7528*# - Simlock Flags
*#7253*# - Total call duration
*#7846*# - Reset to idle disabled...
*#7849*# - Reset to idle enabled
*#3377*# - Config as clam phone
*#2277*# - Config as bar phone
*#3646*# - Engineering module
*#7378*# - Reset informaions
*#6362*# - Free memory
*#3862*# - Test mode -- usually keypad..
*#4837*# - Internal vesion
*#3837*# - Version revision
Older Alcatel Models:
Enter Service Menu : *#000000#
View Secret Menu : 000000 and press *
I locked my sim card and need puk code for my alcatel
PUK codes are only available from your service provider
contact them on another phone , provide proof that you own the account and they will give it to you
I don't have disable auto answer in call setting on my Alcatel One Touch Fierce 5054N. Is there another way to disable auto answer?
have you checked in settings in sounds & notifications then check to see if there is call settings .
How to disable shutter sound of alcatel 918N glory x?
I need to disable ports on my network so that they aren't open for non network workstations to plug into how do I do this on an alcatel 7700 switch
interfaces (slot/port) admin down
eg
interfaces 3/24 admin down
The above example will disable port 24 on slot 3. Admin up to enable it again.
Top Alcatel Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Paul Katynski
Paul Katynski
Are you an Alcatel Lands Phone Expert? Answer questions, earn points and help others
