My toshiba tv does not have the right audio out puts for the new vizio sound bar I purchased and the sound bar does not have a optional audio out let that my tv has what should I do?
SOURCE: Installed a Vizio sound bar and subwoofer.
probably they are on a frequency compatible only on the first input ...so if you want to use them both ...either use a mixing device or an adapter to let you insert them both in the same plug ..anyway ..Im not sure why you go for analog stuff ..and didnt used the regular entries for Tv and dvd ...Probably it doesn't have such thing ..Most systems have though..IN this case...if this is the only entry that works ..you have to use some kinda mixing device to make more than one entry to be channeled in one in-let..
or ..use something like that for to get them both in the same entry ..
this is for a 3.5 jack plug http://www.shopmania.ro/magazin~online-accesorii-audio-video~produs-adaptor-jack-3-5-mm-tata-2-x-3-5-mm-mama~p-7999228.html
this is for rca
http://www.cablesnmor.com/rca-y-adapter.aspx
SOURCE: I just bought a vizio sound bar and am trying to
I found code 1517 for the Vizio sound bar for Comcast and a universal remote- I don't know if codes for your remote are 4 or 5 digit codes, but this is the only one I found that works. Hope it helps.
SOURCE: can you hook the vizio sound bar to an av receiver
Why not ? It doesn't know what the source at the other end of that RCA or digital cable is. Register and download the manual for free at retrevo.com
Picking the VSB200 as an example.
http://www.retrevo.com/support/Vizio-VSB200-Speakers-manual/id/23494ag923/t/2/
The manual shows connections to just about anything.
Not knowing anything about YOUR receiver, you MIGHT be able to draw digital audio out somewhere. Analog audio would be available at any Tape Output. Your receiver
SOURCE: Why is my Vizio VSB200 sound bar not having
my soundbar vsb200 no sound at all what im i doing wrong
