Cell Phones Logo
Anonymous Posted on Oct 07, 2012
My Android 4 wont turn on
After selecting the "update now" on my phone it turned off, when I plugged it into a charger it wouldn't charge, I've tried three different chargers, and I have even tried to restart my phone. I don't know what else to do.
Computer Repairing
Level 3:
  • Cell Phones Master 14,641 Answers
  • Posted on Oct 11, 2012
Computer Repairing
Cell Phones Master
Level 3:
Answers
14641
Questions
0
Helped
719537
Points
53082
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
  • Official Brand Answer 3,100 Answers
  • Posted on Nov 15, 2012
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
685029
Points
13487
Pull battery out. Hold power button for 15 seconds. Place battery back in. place on charger for 1 hour. Then power on as normal.
1 Related Answer
Anonymous
  • 5 Answers
  • Posted on Sep 03, 2011
SOURCE: My Samsung G600 turned itself
your problem might be the battery has over heated this will some times happen when left on charge to offten i had the same problem what i did was take it in to my network previder and they restored it to factory setting keep in mind you'll lose everything or you could pay out and buy a new battery i hope this info has been helpfull in some way Matt
Wont turn on when not plugged in. but will turn on if charg plug is plugged in and you turn on the power switch and unplug the charger it will stay on but wont play, keeps coming up format error.
Customer Reviews: Kubik Evo 8GB MP3 Player with Radio ...
www.amazon.com/Kubik-Player.../B0041MMMWW
Amazon.com, Inc.Find helpful customer reviews and review ratings for Kubik Evo 8GB MP3 Player with ... Con's - Wonder if some of these items can be fixed with a firmware update. ... Just push the main button (or any button) and it will turn on and function as usual. ... 2) Play while plugged in charging works with the wall charger, but still NOT ...
Evo won't charge via USB ' Android Forums
androidforums.com > Android Phones > HTC EVO 4G
Jun 29, 2010 - Whenever I plug in my Evo, I select Charge Only (or if I do nothing, it selects Charge. ... If I turn off my Evo it charges from the USB fine. ... Check your computer's stats... what does it say about its USB status when your Evo is plugged in or ... I had a problem a while back where it would charge via USB, but not ...
tip
WORX battery chargers
I'm going thru same prob. with 24V battery for WG167. Had same thing with older 18V that came precharged & then wouldn't recharge. 3 batteries later, they sent me to a "technical" rep who said "NO NO, it's not the batteries, it's the charger" He sent me a reconditioned charger & it worked fine. I'm not having any luck so far with the "MAX 24V". On my 2nd battery. It didn't come precharged & will only charge to 18V which is what the charger is outputting! Trying to get a "tech rep" to diagnose but no luck so far. Their tools are handy & work well if you can just get the battery/charger resolved!!!
tip
How to Synchronization contacts between Android and Nokia (Symbian and Android)
<p>You cannot directly transfer contacts between your Nokia phone and your phone Android, because operating systems are different. You can import your contacts from your phone using Google Android to Sync your contacts from Nokia to synchronize with their Google account. The Android phone has a feature that synchronizes with your Google account automatically, so you can use your contacts on your Nokia phone to get Android. <br /> <p><br /> <p>1. Go to your Nokia phone. Load your "MFE" folder. Start the Mail for Exchange application on your phone. <br /> <p><br /> <p>2. Select "Yes" if the Nokia will prompt you for a synchronization profile. Click "Connection". "M.google.com" field enter the Exchange server. Confirm that the secure section is set to "Yes", your access point is set to your data connection for your Nokia and the port is set to 'default'. <br /> <p><br /> <p>3. Click on "References". Enter your e-mail in full Google Account username column. Enter the password for the account. Click on "Always On" so that your data is always synchronized. Go to the "Contacts" tab. Select "Enable". <br /> <p><br /> <p>4. Go to your Android phone. Tap your "All Programs" button and go to "my bills". Touch your Google account you just sync your contacts with Nokia. Tap the "Sync Contacts" if it is not synchronized. If your Nokia syncs your contacts with your Google Account pushed the contacts on your Android phone. <br />
on Aug 18, 2011 • Google Android
1helpful
Won't boot up. Error message "
did you try pluging into charger, my galaxy 2 if i run battery all the way down it wont do anything after it shuts down. at times i have had to plug in and wait sometimes 15-20 min before it will even flicker. hope it helps
Dec 31, 2012 • Cell Phones
2helpful
2answers
My transcend MP330 is not gettin recognized by the computer..
1) Turn on your mp3
2) go 2 settings>MTP thn select MTP
3) connect 2 a pc
then you'll see it as a portable device
4) FORMAT IT
5) go 2 settings>MTP thn select USB [on ur mp330]
tip
How to convert contacts from Palm to Android phone
<p>Android phones sync contacts using Gmail contacts online. You can easily import contacts in Android web interface of Gmail. The contacts are automatically synced to the phone. Palm contacts are automatically synchronized with the Palm Desktop software. You can export the contacts from the Palm Desktop software and import them to your contacts from Google Android phone in minutes. <br /> <p><br /> <p>1. Synchronize your Palm device with Palm Desktop software for the latest updates of your contacts are stored on your computer. <br /> <p><br /> <p>2. Click the drop-down menu at the top right of the window of the Palm Desktop and choose your username. Click the "Contacts" component. <br /> <p><br /> <p>3. Click "File" and select "Export". Enter a name and choose a location for the file, such as your computer's desktop. Set the "Type Export" to "Comma Separated Variable (. CSV)" and select "All" as the Range. Click "Export". <br /> <p><br /> <p>4. Go to mail.google.com and log in with Google account you use in your Android phone. Click the "Contact Us" link on the left. <br /> <p><br /> <p>5. Click "More actions" and choose "Import." Select "Choose File and then see the CSV file you created. Click" Import. " <br /> <p><br /> <p>6. Unlocking the phone and the Android home screen, press the "Menu" button. Tap Settings and then "Sync and Accounts." Tap the account name in the Google list and tap "Contacts" to a green checkmark in the box next set. Tap "Save". The contacts will sync between phone in just sum minutes. <br />
Once i plug in my charger its wont charge!
Turn it off, & keep it off for a while. It's happened to me as well. Turn it back on & plug the charger in.
I've had an LG Chocolate 3 for about 3 yrs and love it but all of the sudden it wouldn't hold a charge. When charging it flashes "charging" on the screen but it really wasn't. I had...
i think there is virus infection to your phone in this case Please Visit your Nearest LG Service center they will do the needful for you & this is the only way to solve your problem.
Kindly Visit LG Service center
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
I have had 4 pantech jest phones and it wont charge!!!! i had it plugged in then i thought it was charged fully cause the bars were full when i took it out.....BAM!!!! i shutt of!! im sick of it i had 4...
Make sure you're using the Pantech charger you got with your phone. I had this problem, got a new one, and realized I'd been using my old charger charger. Plugged it in with the wrong charger, it wouldn't work. Plugged it in with the Pantech charger, it started charging up and worked fine again.
Dec 27, 2010 • Cell Phones
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
