Before I buy a used treadmill, I'd like to find out the total mileage and hours it was used. I'm looking at a used Life Fitness 9500 treadmill and when I go to look at it in person, I'd like to see how many miles and hours have been put on it. Thanks so much :)
SOURCE: Life Fitness 9100HR Treadmill won't start
Typically a non start up of any electrical Exercise equipment raises alot of red flags If this treadmill will not start Check the internal fuse MAKE SURE ITS NOT PLUGGED IN!!!! UNPLUG IT FROM THE WALL
2 If there is NO Fuse and you just bought it new Return it for an exchange.
3 Check your wall outlet for less then 5 Bucks you can buy a wall outlet tester that tells you if your Outlet is good Or Bad.4 DO NOT Attempt to service this item on your own the way they make treadmills you have to have a qualified service tech come out and fix it because the risk of serious shock or death is emminent.
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
SOURCE: replacement console
Unplug unit then remove the upper console, their are 4 allen bolts holding it udder the console their is a panel held by 4 phillips head screws also remove them . Look inside the compartment and their should be two connections, disconnect them. Now pull console off its tower. Lay it upside down on a thick towel remove all phillip head screws you'll notice where the emergency stop button is connected. I have found that this connection 7 out of 10 times is causing the problem. Buy cutting the lead connector stripping the wires and soldering back on the male connection will resolve the problem. If not their is a emergency stop kit may be purchased and replace. The only other thing that may cause the problem is the function key pad itself. Try the first solution if your not good in soldiering go to a computer shop , t v shop they should be able to do this very quickly for while your at let the check the switch itself.
Testimonial: "This guy really does know his stuff. I am very pleased I was able to fix the treadmill with absolutely no expense. I simply followed the clear instructions and the machine was up and running in an hour. I would rate this expert 10/10 but actually he warrants 11! maxtreadmill yo da man !"
