It is folded up, and we cannot release it to open it and use it
SOURCE: Need to put together a Nordic Track Elite 2900 treadmill.
Type into the serch, icon health and fitness, then click on the customer service, then click onto the manuals and the instructions should be in the owners manual.
Good luck.
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
SOURCE: nordic track exp 1000 treadmill console
Sound like function pad or upper console I don't know if you can purchase the function pad, but you may have to purchase the entire console and that may quite expensive.
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
SOURCE: our belt is slipping on our nordic track c1900
I have the same unit. First, remove the hood. Then, the motor has an adjustment screw on the belt side of the motor. Loosen the nut a little, adjust the motor up or down to make the belt as tight as you can by hand, then re-tighten the nut. This always fixes mine.
