Need to adjust seveal things on Grandson's bike need to locate owners manual for this unit
SOURCE: CHAIN REPLACEMENT
I think I can help. Place one end of the chain over the rear gear (doesn't matter which one, the biggest) and adjust the lever or twist ring on the handlebar so the derailleur lines up in a straight line with it. Pull the chain from the rear sprocket down and over the pivot wheel and back over the bottom wheel so it looks just like this S and the end comes forward. Join the chain links. Place the chain over a couple front teeth and turn the pedal carefully until the chain seats on the front sprocket.
SOURCE: new mongoose 20'' bmx. trying to adjust the brakes???
undew the screew at the back of the breakes and turn them round slightly so the wheel in midlde then tighten back up should stay in midle then just not put on straight thats all mate
SOURCE: I am looking for a manual for a mongoose tech 4 mountain bike
The brakes should have a label on them so you can find their website. Most of the good manufacturers have directions on their sites for adjusting their products. The bike I looked at had V brakes. http://www.sheldonbrown.com/canti-direct.html is the site to look at. Great pictures and good explanations.
SOURCE: I bought my grandson a Mongoose 24
The following website has a good explaination on how and when to change gears.
http://bicycleuniverse.info/eqp/gears.html
Hope this helps!
SOURCE: New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
