It shows white display when i switch on it, please tell me the solution for it.
SOURCE: Blackberry bold 9700 Bluetooth problems
Many quirky behaviors for these
devices are fixed every time a new software version is released.
You might check that you are using the most current system software for
your BlackBerry Bold 9700 Smartphone.
The
latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
SOURCE: My blackberry bold 9700 keep
Hi, the problem you are having is with the phones firmware you will need to take this phone into a phone shop and have the phone flashed and the firmware re-installed, the problem with this is you can only have it done at a phone shop as they need to install all the software back on the phone and the other problem is that this will wipe the phone so you will lose anything on it.
you can back it up if you have the leads to your computer and the correct pc suite for your make of phone if you dont have this just ask the phone shop to back it up for you.
their is no other way of doing this as you cant get the firmware and re-install it yourself the phone shop will charge you for doing this but it will be cheaper if you go to one of those independant shops instead of one of thos bigger branded ones.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
`2
SOURCE: I dropped my blackberry bold and screen is white with red line
That means no battery, your lucky. Just go to a phone place and try a new battery. I am assuming you already took the battery out and tried reinserting it. Does the battery have red xx's on the bottom, if so it probably fell on grass and the moisture got to the battery some how.
SOURCE: i dropped my blackberry bold 9700 and the screen
can you repair a broken lcd screen on your own without having to send it off as i have got a brand new screen here???
SOURCE: forgot password,just reset my blackberry bold 9700
i typed in a wrong password 10 times and my blackberry automatically wiped off most of my data, how do i restore them please
