Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
Maytag washer LAT4914AAE, top load.......
upon turning the cycle/timer knob to start a load, machine does not fill with water, nor agitates. Machine DOES "spin" when turning the knob to the spin cycle. Therefore, there is power to the machine.
please help..........repair man would be too costly......and machine was purchased in 1995
    Habit-Forming:
  • 36 Answers
Sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Posted on Jan 03, 2009
6ya staff
SOURCE:
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Machine fills up with water then when its suppose to agitate it just stops working will turn timer & push knob in & out & reset then it will work
    How long do you let it sit after the water fills up, somtimes the timer will take a little extra time to get to the point that starts the agitation cycle.
    When it dose this, without pulling the knob out, turn the disk on the timer clockwise 1 click and see if it starts up agitating, if it dose dont worry about it it is normal
    Nov 09, 2009 | Maytag PAV2300 Top Load Washer
    Maytag Neptun will not agitate or spin
    Change your timer. or timer sensor. behind your knobs
    Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
    WASHER WILL NOT SPIN
    This is probably a timer problem. In maytag washers the motor turns in one direction to wash, the opposite direction to spin. The timer decides which direction to start the motor.
    Jul 05, 2008 | Estate TAWX700JQ Top Load Washer
    Maytag Atlantis MAV6451 Top Load Washer Logo
    638 people viewed this question
    Top Maytag Washing Machines Experts
    jimorris77
    Sheldon Dedek
    Bill Long
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
