Machine is saying it is out of order
F2 This error code indicates that drain times are longer than expected.
If the washer won't drain there might be a clogged pump or hose. It's
common for small socks or other small clothing items to get into the
water drain system and clog the hose leading to the pump or the pump
itself. Remove the hoses from the pump in order to remove the article of
clothing. Keep in mind that any water in the washer will pour out of
the hoses when removed.
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced Bios features press Enter you will see what the boot order is set to.
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
If you are unsure on what the boot order should be you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
This will set the boot order.
does anyone know how to fx it?
