Red LED blinks 6 times. Replaced ballast and thermal fuse. tvrepairkits.com offers a fixit kit but, not sure what is in the kit. Guessing it's something in the power supply.
Yes the power supply board is notorious for blowing caps and tv repair kits .com has a good DIY kit for this problem.
I inspected the power supply and all the caps look good. No parts show any sign of failure. Guessing it's an ic chip? I ordered a whole new board on ebay. Let you know if it works.
Troy,
Troy - All of the solutions I've found online have said the thermal fuse was the problem. Only a few said the low B error was from the power supply. Visuaal inspection of power board does not show any signs of failure. Must be an IC chip. New G1 board is on the way. Will let you know.
I ended up replacing the entire circuit board assembly. Replacing just the power supply resulted in the same 6 blink code. Got all the boards on ebay for reasonable price and that solved it. Works great now.
SOURCE: Sony Grand WEGA KDF-60XS955
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
SOURCE: my tv sony kds-50a2000 dont tur ON
I have a Sony KDS-50A2000 50 in. HDTV Television. I just replace the lamp because I got the message that appeared on the TV. Lamp needs to be repaced. I replace with a Sony lamp and now TV cut off after 2 to 3 hours off watching the TV. Any Idea what is going on with this TV
SOURCE: XL 5200 bulb replace and tv still down
3 blinks means the lamp cover door is nit properly attached. Remove the lamp door and reinstall it
