Tannoy v1 reduced brightness from one tweeter, diagnose? replace? honestly unsure if broken tweeter is the duller one or the brighter one, help?
Played too loud briefly speaker became bright then dimmed, i thought i had got away with it, now one tweeter is significantly dimmer than other, not distorted just dimmer at very high freq. i'm not even sure which speaker is correct?..when i listen close to tweeter it seems fine no distortion, could my cross over be damaged? tannoy have quoted a price for a new tweeter, i'm worried if crossover is the problem, any help or guess would be very welcome.
  • Audio Player... Master
  • 5,699 Answers
I assume you have more than one of these speakers. If so simply remove the tweeters from the two speakers and swap them around. If the other speaker acts up then, you know the tweeter is faulty. However if it stays on the same speaker it's the crossover that's the problem.
Posted on Jun 12, 2017
6ya staff
SOURCE:
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: tweeter plays and very low volume when in back by
This sounds like I would be trying a new crossover network module.
Jerry G.
Posted on Aug 06, 2009
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Distorted output
check the audio output of the amp they could be damage or look around for some defected cap diodes or transistor in the audio circuit.good luck.
Posted on Apr 14, 2007
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: BOSE 2 AND VCSX OVER DISTORTION
have a tech look at your set you have some bad caps in the audio circuit along with your audio out put transistor or ic.have it replace along with the bad caps.good luck my friend.
Posted on Jun 16, 2007
lluisferrari
SOURCE: Mackie SRM-450 tweeter distorts sound
I wish to change access to the diaphragm
Posted on Jun 16, 2010
John Bato
  • 7 Answers
SOURCE: I have a pair of jamo R909 speakers that need crossover / board replacement--- any thoughts or suggested repair options? The company has been horrific. Love the speakers, but the company doesn't s
Hi Katrina,
Yes parts are available for your R909 speakers.
firstly I am surprised that you have managed to blow both tweeters and crossovers.....there must of been some serious distortion/amplifier clipping involved there???
So a couple of things.
Can you actually see damage to the crossover boards? If so what components have been damaged? i.e board loactions and parts.
The crossover is available but they are not cheap. $1560 each (AUS)
So it would be preferable and much cheaper to repair them at board level.
Tweeters are also available.. $745.00 each (AUS)
Regards John
jb@qualifi.com.au
Posted on May 15, 2012
I work in a church that has 4 passive speakers across the room, 3 out of 4 of them sound super muffled and n one of them sound perfect Ive tried switching power amps, there is no processing help?
I would say from your description that the tweeters are blown.
Can you take the speaker that sounds good and swap it out with one that sounds bad. If you do that and the good one still sounds good. You have a tweeter problem. And they would need to be replaced.
Apr 01, 2015 | Tannoy Audio Players & Recorders
I just bought a pair of Tannoy Mercury V4 with a broken tweeter. Where do I find a new one?
check to see if you can find it on parts-express.com that's where I get all my speaker stuff
May 28, 2013 | Tannoy Audio Players & Recorders
Tannoy reveal speakers have lost treble
What you need to do is connect a 1.5 volt battery to the speaker(s) terminals for a split second. Put your ear to the tweeter at the same time (you might someone to help you do this). If the tweeter "pops" it works, if not you might have blown them. The best way would (to be certain) is to remove the tweeter from the crossover inside the unit.
Tweeters are the first thing to go when the speaker has been connected to an amp that is wrong for them or they have been run at high volume.
Apr 20, 2010 | Tannoy Reveal 6D Speaker
When I unplug the mains adaptor on my laptop the screen goes brighter and then duller when the mains reapplied. How do I change it around
This is usually a BIOS adjustable feature. During startup, press the proper key (*) to enter BIOS. Look for LCD or something that would deal with brightness. Make the adjustment as desired.
You can adjust the brightness while running the computer using (usually) the function key and the brightness key. But only the BIOS adjustment will be permanent.
(*) Each computer manufacturer has their own key to get into BIOS so Google for your brand to see which key it is. Usually f2 or f10.
Nov 12, 2009 | Dell Computers & Internet
Can i get a tweeter for tannoy 607
ya.. u can.. you can check here, here.. Thnx
Aug 17, 2009 | Tannoy (ST100) Speaker
Faulty tweeter on tannoy 633
Hi there, the best place to look is on ebay, but 1st take it out of the casing using a small allan key and check that the terminals are intact. Its very easy to do and replace if need be. You are looking at around
Mar 17, 2009 | Audio Players & Recorders
Replacement tweeters for Eyris 1
If any new readers are seeking the same advice, then as at Feb 2016, replacements are available from Real Electronics in the UK, 08452 307 747 - this info from the service line at Tannoy. £63.21 + VAT + delivery. Part no 7900 0621
Much of the advice above is not applicable to the Eyris, folks seem to be posting generic solutions.
Unbolt the hex bolts at the rear of the tweeter assembly. With a screwdriver or similar, push the threaded rods forward to move the front portion of the tweeter housing free from the cabinet. The amount of flexibility in the cables may vary, and some users may have to remove the terminal block (hex bolts again) on the rear, and remove the acoustic wadding to gain flex in the cables.
There are three terminals on the tweeter, with push-fit spade connections. Green for Earth, red/black for signal. Disconnect these, pull tweeter forward, remove threaded rods.
Reassembly is the reversal of removal. Ensure all cables go in same places, etc. etc.
Mar 16, 2009 | Tannoy Eyris 1 Main / Stereo Speaker
I brought a pair of tannoy sensys dc1 bookshelfs a couple of years back and always thought i needed an extra cable for the super tweeter as i saw wires for it else where. but lately as i went to sell them...
On the images on Google for them there are no extra wires. Where are the wires on them? Do all the drive units work?
If the wires are for the super tweeter. Then looking around at the Google images it should be possible to unscrew the 4 screws holding the tweeters on top and you should be able to push the wires back inside the unit, if they are not connected to anything. Or at least see where they do connect.
Jun 02, 2017 | Tannoy Sensys DC1 Main / Stereo Speaker
My Tannoy Reveal 6D Monitors are only outputting sound from the tweeters. I'm looking for troubleshooting suggestions.
I still suggest calling Tannoy, They are usually very reasonable and will give you a fair price to service a very good product
Dec 02, 2008 | Tannoy Reveal 6D Speaker
71 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
