SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
SOURCE: Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
SOURCE: KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
SOURCE: What causes the ice cubes in my ice maker fused
Good day,
If the temperature in the freezer is good and consistent, then it is the dual water valve on the rear of the machine, that is not shutting off properly.
The system turns the water valve on for 7 seconds just before the ice maker parks waiting for the next harvest cycle.
Many times the valve will be too slow in closing or continues to dribble even though no power is being applied to it, thus causing the well of the ice maker to overfill and overflow.
Replacement of the water valve is the only solution and is a very common problem.
Testimonial: "Short, direct, well explained, and an unambiguous solution! Thanks"
