My 2004 ice maker has had the pump replaced (again) and has been cleaned several times with the Nickel solution and by hand. It runs a cycle, produces a sheet of ice on cutter, cutter seems to be working, but ice is not normal size, much smaller. After a cycle, it shifts to blinking clean light. Turn it off and back on, it will repeat. Seems a little warmer than normal, but not too hot. Help!?
Whenever the unit has reached a failure mode, the LED will flash, and the unit will shut down. If the failure was caused during a harvest cycle which lasted more than 16 minutes, the LED will remain flashing on & off in halfsecond increments. If the failure is caused by a faulty bin thermistor, (not detected), the LED will remain flashing on & off in 1-second increments. These are the only two failures that cause the unit to reach a shutdown failure mode. x During the Clean cycle, the control board performs the diagnostics first. If the bin thermistor is not detected, the LED will flash two times. This is followed by a 3-second delay. If the evaporator thermistor is not detected, the LED will flash on five times. This will be followed by a 3-second delay. The LED will then come back on, and remain on for the remainder of the Clean cycle, and until the unit is turned back on.
SOURCE: ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
I'm still perplexed with this problem. I have unplugged the machine before, to no improvement, but I just unpluggedit and plan to leave it unplugged for a few hours instead of a few minutes. I keep reading that there is some way to decipher hte blinking red light on the clean mode, but I cannot find out that code.
Update: Unplugged the machine for the entire day. Plugged it back in this evening and turned it on. Immediately started to work, pumping the water and made a sheet of ice. As the ice started to drop into the bin, I noticed the clean light was blinking aagain and it felt warm. Put a thermometer in the bin and it reads 52 degrees F and the front control panel feels warm to the touch. Any ideas from this?
