HewlettPackard HP LaserJet Pro CM1415fnw Color Wireless MFP New - In Box Logo
marlon Posted on Oct 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i plug my hp laserjet pro cm11415fnw to 220-240v,
Im in the philippines now,i bought my printer in canada,the power supply is 110-127vac,the voltage in the philippines is 220-240v,,can i plug my printer to this type of volts?
Nolan Brunsdon
Level 2:
  • Expert 124 Answers
  • Posted on Oct 17, 2013
Nolan Brunsdon
Expert
Level 2:
Answers
124
Questions
0
Helped
26694
Points
249
Some printers have a setting for swithching volts where the power cable plugs into the printer but if it doesnt it will make a big bang and that will be the end of it.
HP LaserJet Pro MFP M130fw. Error code 58.04 Laser jet pro mfp m130fw
Question edited for clarity and toss in a load of CAPS.
Question moved from 'Jet Office Equipment' category.
It's not good!
HP Color LaserJet Pro MFP M477
Printcopy.info https://printcopy.info > brand=HP > code=58
Code: 58.04; Display: 58.XX Error, Turn off then on; Description: The product has experienced an error with the low voltage power supply.
Missing: M130fw. ‎' Show results with: M130fw.
58.04 printer display error on powerup
HP Support Community https://h30434.www3.hp.com > td-p
Aug 2, 2018 - THE ERROR CODE PROBLEM OF MOTOR POWERSUPPLY BOARD (SMALL DAUGHTER BOARD TOP OF THE SCANNER UNIT), Transistor no of 905,903 like ..before you change check motor ...
My printer is displaying, "58.04 Error power outage detected...
Jun 28, 2022
Laserjet Pro 400 MFP 451dn error message 58.04
Aug 5, 2013
My laser jet MFP M477fdw printer is showing 58.04 error cont...
Sep 22, 2021
HP M451 Error 58.04 - HP Support Community - 5830295
Nov 1, 2016
More results from h30434.www3.hp.com Missing: M130fw. ‎' Show results with: M130fw.
Error Codes > HP > LaserJet Pro MFP M130 > Code 58.XX
Code: 58.XX; Description: The product has experienced an error with the low voltage power supply. • 58.04 = Low voltage power supply malfunction; Remedy: 1.
HP LaserJet Pro 400 M401n printer power button blinks but won't stay on.
It seems you have done all the troubleshooting yourself. You can't do a full factory reset, because you can't see the screen. You either have an internal power supply unit failure or a control board failure. Neither are really home repairs. A new one is $147, or you can take it to an HP Service Centre. I am sure not to answer you wanted but it has failed.
Here is a Troubleshooting Manual. HP always do things in style! Low-voltage power supply on Page 34.
HP LaserJet Pro 400 M401 Printer Series Troubleshooting ...
Laser Pros International https://www.laserpros.com > img > hp-manuals
If the hardware or software configuration has not changed or the problem is not associated with any specific software, see the complete service manual for this ...
166 pages
Here is the Service Manual. It looks like the power supply PCB is behind the button. The main PCB is on the right side above the cassette.
HP LaserJet Pro 400 M401 Printer Series Repair Manual
Printer Parts Exchange https://www.printerparts-exchange.com > upload
English repair manual (this manual). CF270-90977. HP LaserJet Pro 400 M401 Printer Series Troubleshooting. Manual. English troubleshooting manual.
118 pages
https://www.google.com/search?q=HP+LaserJet+Pro+400+M401n+reset
https://www.google.com/search?q=HP+LaserJet+Pro+400+M401n+printer.
2answers
Camera error 1000 hp color laserjet pro 200 M275 wireless
Try updating the printer firmware and check if it helps. Reset the printer to clear certain error states by calibrating the scanner mechanism, and then check the power source to confirm the printer is getting enough power to operate the scanner. From:
https://h30434.www3.hp.com/t5/Scanning-Faxing-and-Copying/Hp-laserjet-pro-M275-camera-giving-camera-error-1000/td-p/6965213
https://support.hp.com/us-en/product/hp-topshot-laserjet-pro-m275-mfp/4346268/troubleshooting
What is 59.A0 Error in hp laserjet pro 400 printer?
This is usually a motor code, turn off, unplug wait 2 to 3 minutes plug in and try, may work good luck
How do i fix E59.00 on Hp Laserjet Pro 400 color M451dn
The 59 error indicates a motor is not functioning. check all the wiring to make sure you did not leave something disconnected after you fixed the power supply.
2answers
Supply error
make sure you have removed an orange small plastic piece if u don't remove printer will detect it as a Supply memory error
hp laserjet pro m1213nf mfp driver Software downloads Hp Drivers
79 service error hp laserjet pro 200 m276nw
I had the 79 service error on my Laserjet pro 200 m276nw. The manual says this is "The product has experienced an internal firmware error." and gives no further diagnostic steps. Thanks HP for nothing!
Repair manual downloads:
https://www.printersupplies.com/amfile/file/download/file/20/product/5896/
https://www.laserexpressinc.com/manuals/HP/hp-clj-pro-200-m276-troubleshooting-manual.pdf
The initial symptoms was that it would randomly restart and then get stuck in the 79 error. If you turned the printer off and on, it would get stuck in the 79 error about half the time. It would get to the part where it runs the sheet scanner motors with a kind of sickly sound and then just quit.
To view the diagnostic Error Report log on the secondary service menu
Click on setup icon,
Touch middle left below home button and lower right below question mark.
to activate 2nd service menu to print error report
The Error Report had an error:
Abort
Task: IO_usbhost_urb_complete
I found that all of the boards for this printer are relatively inexpensive, so I bought every board for this printer on Ebay.
HIgh Voltage Power Supply: RM1-8705 HVPS $24.95
Fuser Power Supply RM1-8709-000CN $20.00
Formatter w/wireless card CF224-60001 $42.00
DC Controller RM1-8704 $25
Low Voltage Power supply RM1-9012-000CN $34
Universal Serial Bus (USB) CF368-60001 $13
Things only got worse. The yellow toner stopped working and the remaining colors were out of alignment. It would also only print in black and white. It then began to print solid black pages. I was about to give up, so I began putting the old boards back in since it seemed to be getting worse after spending $159 on parts.
I replaced the formatter board which didn't do anything. Then I replaced the DC Controller board and BINGO, that seemed to fix the printer. I don't think the board itself was defective, but maybe there was a loose wire or connection that eventually fixed itself with the install/uninstall process. I'm still not sure and I'm not going to mess with it while it is working since these multi-function printers are expensive to replace. So, if you get the dreaded 79 error, you might try to unplug/plug every connector to make sure everything is tight.
3answers
Error 22
Go to hp website and look for firmware update. The model M1217 had the same issue which was fix in a firmware update.
HP printer
Try to unplug then plug in the power cords if not working im sure your current supply will be lost. due to the current supply in your area or lost connection of your power supply.
Top HewlettPackard Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a HewlettPackard Office Equipment and Supply Expert? Answer questions, earn points and help others
