This tv was moved to another location and it will not power up. The lcd light on the front will come on and go off by using the master reset switch on the back, but no power to the tv.
HI, i did what Mr Jeep says, i cant believe it but IT WORKS!!! Weeeeeee!!! XD, here are the steps:
1) I found (it was pretty hard) a firmware that works for the 437 S11 model, the 237 S11, you can use it with no problems, in the Folder you will encounter a PDF files, read it first, there mention all the steps
2) the other thing that you need is an USB A to USB B cable, this the USB cable that all Printers use, or you can go to an electronic store and ask for them. You have to Connect the USB Cable from the TV Service Port for Firmware Upgrade in the Back of the TV and then connect to your PC or Laptop
3)Here is the Link: http://dl.getdropbox.com/u/1022277/237-S11_061218A.zip
And remember to follow all the steps, doesn´t matter if the TV is OFF, just be sure the Power Plug is connected and the Power Led it´s ON.
Hope this work as works for me, See ya!!!
P.D. If you need some information, you can contact me at [email protected]
Hi there
I solved my problem by downloading new software from I can't remember the website (it's been about 5 months) and loading it via USB cable. I can't believe it worked but it did. You should try Google search and look for troubleshooting tips for your tv. Include model and serial numbers. When you download new software make sure you have the correct software version and find and follow directions as to how to get it done. Let me know if it worked for yah...Good luck and a happy new year.
I have an Olevia tv model LT23HVX that won't power up
This unit won't even click. the blue pilot flashes continuously
