Question about Datamax Office Equipment & Supplies
Datamax ex2 dc power supply specs
Hi, could anyone tell what is the dc output specs for datamax ex2 printer power supply? thanks
6ya staff
SOURCE:
Anonymous
SOURCE: How to check the PSU for IP3000 printer
I've just checked mine as it suddenly stopped working - does not even light up the green button.
I'm getting 8 volts Red to Black and 23 volts Red to Yellow so I guess it's fubared?
Posted on Jan 28, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 26, 2008
Anonymous
  • 16 Answers
SOURCE: WD320 mybook power supply is lost
the transformer I have says:
DC output: 12Vdc == 2A
hopefully that helps...
Posted on Aug 19, 2008
Anonymous
  • 399 Answers
SOURCE: lexmark printer x73
you can get the proper power adaptor at just mention them the proper model number of your printer and they will provide you perfect adaptor
www.radioshack.com
thanks
Posted on Sep 18, 2008
Anonymous
SOURCE: power supply for a 5500C
Delta Electronics
AC Adapter model ADP-36XB REV. B
Input:AC 100V-120V~850mA 50/60Hz
Output: 24V 1500mA LPS (Center positive)
Made in Thailand
Posted on Sep 21, 2008
Light flashes hit button prints
my kyocera taskalfa 180 showing error code c6400 please help.
Jul 15, 2013 | Datamax Ex2 Thermal Label Printer
If someone has an original Sega Genesis 2 power supply, can you tell me the exact volts, amps and polarity that uses? I know there's a lot of adequate replacements, but I want to use one that matches Sega...
Well I'm happy to say that i have a genesis 2 power supply on me Its specs are
  • Input: 120v AC 50 Hz 15W
  • Output: 10v DC 0.85A
If you don't have the required power supply already or can't find one you can find a replacement here
Feb 11, 2011 | Sega Genesis 2 Console
I have an old SPX90 Digial Reverb with a dead powersupply. The part number on the board is VA81400. Is this part number correct? Is the part still available? We tried ordering it from the Yahama dealer,...
Any power supply will do as long as it has the same specs as the dead one, which will be:
Input : x Volts AC
Output: x Volts AC or DC
Watts: x
Amps: in millamps
Polarity: (for power supply with DC output only) Center pin = plus or Center pin = minus
You should be able to find the matching transformer/adapter/power supply at Radio Shack.
More info, let me know.
Charlie
P.S. The power supply you received may be the correct one -- check to see if the specs match the old one.
Aug 29, 2009 | Audio Players & Recorders
I misplaced the power supply for my visioneer 4400usb scanner. Can anyone tell me the voltage output to the scanner?
Power supply
Input voltage/frequency 100 Vac, 50/60 Hz (Japan)
120 Vac, 60 Hz (North America)
230 Vac, 50 Hz (Europe)
Output voltage/watt 12 V DC, 15 watt maximum
May 24, 2009 | Visioneer 4400 Flatbed Scanner
Can anyone tell me if the 12 volt powersupply is 12 volt AC or DC ?
Model HER-48-12010
P/N: 68300021-0013
AC Input
DC Output
Sep 20, 2008 | Compaq S 200 Flatbed Scanner
Adapter specs
hi..
i've also got one without DC adapter... and looking around. find this link here: http://www.corg.ru/products/Network%20equipment/Compex/TP1008C saying: Power Supply: External power adaptor input 220V-110V, output 7.5v/1A
hope it helps
Aug 07, 2008 | Compex MicroHub 8 Networking Hub
Microsoft Force Feedback 2 joystick - Lost Power Supply.
Hope this helps.
Part No. 96749 (Maybe Ebay?)
Input: 230V~ 50Hz
0.15A
Output: 12V 1.3A
Apr 28, 2008 | Microsoft SideWinder Force Feedback 2...
PrimeFilm 1800u power
Power Adapter:
Output -12V DC /1A , Input - 100VAC or 240VAC, Frequency: 47Hz to 63Hz
Feb 13, 2008 | Pacific Image PrimeFilm 1800u Film Scanner...
AC/DC Adapter
Hi, You would need an adapter that puts out 12 Volt DC, Output Current: 3.3 Amp and the Center Positive Power Tip (Output Power: 40W). The original ViewSonic adapter is M/N: UP06031120A Hope this be of some help/idea/ Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
162 people viewed this question
Top Datamax Office Equipment & Supplies Experts
rongg
Joseph Mueller
Joseph Mueller
Pierre Legault
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
