I had a paper jam and needed to wait until the machine cooled down to get the paper out. The machine now says that there is still a paper jam even though there is no paper in the machine. I was told that the Jam Code is 121. I need to know how to reset the Jam Code 121 please.
SOURCE: Gestetner CP6123 giving error E12
You should check the all paper sensor, there must be a pieces of paper in some sensor and make the sensor in wrong direction. You should remove all and off the power for a while and the start to use it.
SOURCE: Had a paper jam. Cleared the jam.
you have go to SP mode to reset it;
1, power on,
2, press "clear mode" enter107 and "clear/stop" for few second
3, press "copier SP mode
4, turn power off (5 second) and back on.
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
SOURCE: Gestetner 2822 error code e-5
i got a strait black thin line on left marging of paper. i think margin setting of my Gestetner 2822 has been changed. but i don't know how to fix this problem. (107-C, ???)
SOURCE: I have a Gestetner DSm415pf and am tryint to set
Sorry no can do. Only the spf has that function.
Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly. Click this link HP All-in-One and Fax Products for more information on enabling or disabling ECM.
NOTE: Error codes that apply specifically to ECM have ECM listed next to them.
Error Code: 356, 357, 358, 359, 360, 361, 362 ECM, 363 ECM, 364 ECM, 365 ECM, 366 ECM
Definitions
Solutions
