Hey, my phone just recently started having a bunch of black exclamation points with yellow backgrounds as the pictures of the menu thumbnails as well as other options for the phone
Mine one also the same problem (yellow background and touch screen not working as I tapped the screen--> seem like software hung!!)Mine one also the same problem (yellow background and touch screen not working as I tapped the screen--> seem like software hung!!)
You can't post conmments that contain an email address.
I recently purchased a 2005 Z4 (76,000 miles), and I just experienced the same thing (beep, then yellow Brake and Triangle Light (w/exclamation point/semicircle appears on dashboard). It is intermittent. Did you ever find a solution?
hey Jim your stereo should have a bunch of wires @ the back of it 1*black=ground 1*red=positive and yellow = battery the yellow wire is your memory wire now both the red and yellow must be connected to the battery and the black must be grounded to the cars body the rest of the wires is all speaker outlets NB!!! don't forget to fit a 60 amp fuse when connecting it to the vehicles battery
go to start menu..CONTROL PANEL. open network connections. then right click to your local connection that indicate with yellow exclamation point.. then repair.. if you use manual ip address try right click to your local connection that indicate with yellow exclamation point.. then this time properties... double click INTERNET PROTOCOL(TCP/IP) then select "obtain an IP address automatically" and "obtain DNS server address automatically...
Checking
ink levelsUse one of the following
methods to check the ink levels.
Method one:
Check the ink levels from the HP All-in-One
The ink level is displayed on the main screen
of the control panel display. Locate the two icons that represent the
print cartridges. The icon on the left is for the color cartridge and
the icon on the right is for the black cartridge.
The
exclamation mark (!
) symbol indicates a low ink level.
The question mark (?
) symbol indicates the product cannot determine the status of the print
cartridge. This might be because the cartridge is refilled.
Figure
1: Ink levels on the control panel display1 - Exclamation mark indicates low ink in the
color cartridge2 - Ink level in the black cartridge is OKMethod two: Check the ink levels from the
computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP
Toolbox.
Make sure the product is on and
connected to the computer.
Open HP Solution Center
Windows XP: On the Windows
taskbar, click Start
, click All Programs
, point to HP
, and then click HP Solution Center
Windows Vista: On
the Windows taskbar, click the Windows icon (
), click All Programs
, click HP
Windows 2000: On
the Windows taskbar, click Start
, click Programs
, point to HP
Click Settings
Point to Print
Settings
and then click Printer Toolbox
. Printer Toolbox
opens.
Check the
ink levels displayed on the Estimated Ink Levels
tab.
