Tried to turn tv off,cannot turn power off to tv from remote or at tv.no volume control or channel contol.no channel,volume,or any other button either on tv or remote.unplug tv plug back in. power turns tv on with either remote or at tv unit,but no picture and still no function control from tv unit or remote. still no picture only vizio lite comes on then nothing.have to unplug to turn power off.
tv-vizio vw32l hdtv10a
Why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
505, 506, 516, 523, 526, 566,
573, 612, 627, 647, 652, 653,
654, 655, 656, 658, 659, 664,
665, 667, 669, 670, 679, 680,
704, 717, 730, 738
Try each of the above codes in turn until you find the one which works best, i.e. controls most functions. This may be limited to contolling the power, volume and channel functions. I have also pasted the programming instructions for your remote below, in case you need them.
Regards,
BElectric.
NOTE: Before you start, locate the remote codes for the TV and write them down.
Follow these steps to program your remote control to work with your TV:
rjw34 how did you fix this. I have the exact same issue. The white light comes on and I have to unplug it to turn off. is there anyway you can contact me @ [email protected] to help?
thanks
hi i have the same problem and would like to know how you did fix it, our tv is only 2 weeks old. picture went to a fuzzy scrren like the cable went out and loud sound so i shut it off and now, no control on anything , i can only turn it on. PLEASE help! email me at [email protected]
thanks ryan
OK, my Vizio 37" Tv is doing this and I would like to know if it can be simply solved or else I pack it off to the repair guy. - Coz
controls work at tv, but not remote. replace multiple batteries.
I have a 42 inch vizio plasma tv and the vizio light is on but can't see a picture or hear any sound and the remote doesn't work for anything.
I HAVE A DARK BLUE SCREEN TV WILL NOT SHUT OFF USING REMOTE OR TV BUTTONS NO CONTROLS WORK THERES NO SOUND ONLY THE VIZIO LIGHT COMES ON
i have the same issue. tv turns on but no picture and none of the
controls work. i have to turn it off by unplugging it. any help much appreciated.
RJW if you get this can you email me at [email protected] ? I have the same problem and would love for you to point me in the right direction!!
I have the same problem I turn on the TV and the only thing that comes on is the Vizio light I have no control from the panel or the remote and I have to unplug it to turn it off.
I would appreciate any help you can give me.
Thank You
When TV is on volume goes off, but if you turn tv off then back on volume comes back on. But this happens all the time
Vizio E322AR Smart TV won't turn off.
the power indicator light is on, but it seems to be half as bright. I cant shut off the tv nor can i get any kind of picture. in order for it to work correctly I have to unplug it and plug it back in. this happens mabye 2-4 times a quarter
No picture or sound, light comes on in the front and have to unplug tv to turn it off.
When I try to turn the tv on , the VISIO light turns on but then goes right back off.
unplugged and held on button for 30 secs per vizio and then plugged back in had light on but it faded in a few secs vizio says powerboard
Unit will not turn on either with the remote or the power button
