I have the original MS Combat Flight Simulator that was written for Win 98 SE. I recently purchased a Logitech Extreme 3D Pro USB joystick. The game will not turn flight control surfaces (ailerons, rudder, and elevator over to the joystick. The program installs properly and the graphics are correct. I can fly with the keyboard, but the controls are not as responsive as they should be, etc. Windows 7 Home Premium 64-bit is my OS. I have the latest driver/profiler for my joystick. Windows recognizes the joystick properly. In calibration mode everything works just as it should. There is a disconnect between the game and the OS and the game. What gives? Any ideas? My computer is a basic Dell Inspiron 570 running a 3 GHz AMD Athlon II dual-core processor. I have 4 GB memory on board. My graphics memory is set in BIOS for 512 MB.
SOURCE: vista
alright i believe i have found a good working vista driver for the logitech attack 3 to get it please follow this link. sure hope this works for you.
if this was not helpful please do not hesitate to re post and let us know.
Regards: PC Pro
SOURCE: installed joystick extreme 3d pro wiil not work
Sometimes on those games, if you used a mouse originally, they do not auto-detect that ur using a joystick now - go into the options tell the game ur using a joystick and also there you may be able to set custom control features (what button does what).
Please let us know how it went.
**.The best way to acknowledge contribution is to rate it's relevance.**
SOURCE: Combat Flight Simuulator changes Logitech Attack 3 designation
ok go to this site and reinstall the logitech gaming software.
http://www.logitech.com/index.cfm/441/302&cl=us,en?softwareid=3916&osid=13
once on that screen select multilingual 64-bit, this should fix your problem.
SOURCE: Attack 3 joystick won't work
Hi Jnmjohnson555,
As joystick is a device for interaction with your computer in a specific manner like gaming , this device will be reflected in the human interface section.
However as far as the problem that you have decribed is concerned, I would recommend you to first remove any drivers or softwares that you have installed for this device , and then restart your computer.
Once you restart make sure that you plugin the device or connect the device and your computer will detect it , i.e. it will detect that the device has been connected, but will try to search for drivers.
Now when you find this option , you have to download the driver from the below link :-
http://driverscollection.com/?file_cid=39076550964a71ad1552f680cc6
Copy and paste the above link in your browser and it will go to the download page , there you have to enter a code that will help you download this file.
Once downloaded , you have to install it and then restart your computer, you will find that the device manager reflected this device properly and it works properly too.
Hope that helps...:)
