My problem is the beeper inside the car. i want to disable this because it is beeping when my door is closed and my headlights are on. i have to turn on and off the lights in order for the the beeper to go off. when i do that that, shortly the beeper will return. i followed the noise and the beeper seems to come from the passenger side kick panel. i unplugged the clip and the beeping went off, but my reader lights dont turn on when i open the door. my windshield wipers dont return when i turn them off and the automatic locks no longer work. i plugged the clip back in and everything return to normal as well as the annoying beeping. what can i do to get rid of this????? PLEASE HELP MEEEE! My vehicle is a 1995 Chrysler Lebaron 3.0 turbo convertible. Thanksss
SOURCE: Front passenger door won't open.
you may need to get a slim jim to open the door to make the repairs -jeff please rate
SOURCE: 1998 Jetta Passenger Door Won't Unlock
I had a similar problem with my son's 1998 Jetta K2 4 door. I sprayed loads of WD40 into the locking area from the end of the door through the clip slot, worked the mechanism sprayed some more and finally it start working. My mechanic said these are very prone to moisture causing rusting on the moving parts.
SOURCE: Door will not slide automatically; emits loud beeping noise
Something similar to that was happening with our Odyssey...the beeping when you are driving whether it's ongoing or intermittent is the "safety alarm" letting you know the door is not closed. The power lock is not engaging. What I do when I get the beeping while driving is hit the Door Close button. It causes the door to attempt to engage again. To fix it...we first cleaned out the space below the side running board (kids were hiding crayons and things in there), then looked for any obstructions along the top and bottom tracks. I sprayed a lubricant along the tracks (I'd suggest the dry lube kind...I used WD40 the 1st time and had streaks of it dripping down after driving), use a lube that has a long straw to spray in small places...and spray up into the track that runs the length of the middle of the car. Manually open and shut it a few times to get the tracks lubed, then try it out.
If you press the open OR close button by remote or in the car and get nothing...no movement/no noises/no beeping...then it could be the electrical circuit itself, the signal itself may be impeded...or the motor shot. Have you tried any of these suggestions before?
SOURCE: 2003 Volkswagen Jetta Door Ajar Light wont turn off and car alarm
The problem you are experiencing is the drivers side interior light switch is not working. This is usually found in the door latch on later model cars and usually requires the complete latch mechanism changing. However it would pay to check that your car doesn't have a pin switch fitted in the pillar.Unfortunately I think you have the former.
Michael V, did you ever fix this problem? I'm having the exact same issue.
