I need to program the dish network code to the Disney tv and when I called Dish Network their one code did not work so they told me to call Disney
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Try echostar\dishnetwork code 759. This is listed in the echostar 6.2 and 6.3 remote manuals as a TV code for Hisense.
Unfortunately this code is not in the 6.0 remote. I have the same TV and verified code 759 operates the television with a 6.3 remote.
I lost remote i need a code and brand to set a universal remote
The dish network code for a pink 13" disney princess tv is 720 using a uhf pro tv2 remote control. (and also for the tv1 ir remote)
