I want to set my nokia 1280 keyguard code ... but i forget last code ..so how can i set me new code ..how can i remove my last code
Read more: I want set key guard code of nokia 1280 ,, but i forgote previous code.. how can i set my new code? - I want to set my nokia 1280 keyguard code ... but i forget last code ..so how can i set me new code ..how can i remove my last code :: Ask Me Fast at this IMEI Code 355205055682955
I forget my sekuriti code imei 35828041417156
SOURCE: nokia keyguard code forgot
Dear user,
To unlock With-out entering the security code,
Just click on the unlock button ,then the back
button frequently.
then , press the unlock button again till a * will appear on
the screen for a very short period of time, press the *
button and you'll unlock the code without entering security code.
Normal
0
false
false
false
MicrosoftInternetExplorer4
This is your Master Code :
5257113034
This Master code will help you change your
Normal
0
false
false
false
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Security Code
Goodluck. :)
SOURCE: Unlock Keyguard code
My Keyguard code forget and IME No. is : 357071006807564 please give me a solution and Model No. : Nokia 1600
SOURCE: How to crack key-Guard code NOKIA 1100
yes,
Sometimes it happens,when we push the sim card too hard into the slot.
So,put the sim card firmly into the slot to start the mobile without that text message.
To get the code to you,I need the IMEI number.To get it type *#06#.
"Rate high if you are satisfied with the problem"
Thanks
SOURCE: I had forgot my security keyguard code of Nokia 5220
I had forgot my security keyguard code of Nokia 5220 xpm.
imi no is356840020414727 plz tall me
Warning : Do not enter any wrong unlock codes on your Nokia 1280 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 1280 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 1280 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 1280.
3 - Compose #pw+CODE+1#.
4 - The Nokia 1280 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 1280 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 1280
