At
http://expert-cm.ru/images/stories/shemy_tehnich/exprelia_hd8854.pdf
I found the maintenance manual. It describes how the water level in the drip tray is measured. For me thoroughly cleaning the small overflow compartment in the front right of the tray solved the problem.
Needs to be cleaned i would think.
SOURCE: Hi, I have a Saeco Talea Giro Plus machine and
Hi Natasja, try pull out the driptray and dreg draw while the machine is on and wait about 10 secs. When the red light start flashing, put the parts back. The red light should dissappear. Good luck.
SOURCE: Saeco Espresso machine - Empty drip tray (all the time)
Clarification: It complains constantly. Even when I empty the drip tray, which is already empty, put it back in (empty) - it still wants me to "empty the drip tray" again. Sometimes - if I'm lucky - I can brew 1 espresso before it wants me to empty the drip tray.
Thank you for your assistance!
SOURCE: Saeco talea ring coffee machine reurning error code
Thanks Johnny,
the machine wont make coffee at all as it stands. Justn returns code 1 as soon as you push the button for coffee. Is the sensor optical or a microswitch? Can you tell me where the sensor is located so that we can have a go at cleaning it?
SOURCE: Saeco Talea Ring Plus: often, water flows out of of water steam
The valve parts need to be replaced, if it is only happening when brewing coffee then there is so much pressure on the pump that it is forcing the valve open. First try adjusting the amount of coffee be added to the chamber for brewing.
its looks like a magnet attached to the drip tray i hit it one the floor couple of times and it was fixing the problem but now even that not working
