Question about Sony STR-DG800 Receiver
No Video or Audio on HDMI on Sony STR-DG800
I can hook up my Toshiba SD-5000 DVD Player to my LG 50" DVD (Using an HDMI cable) and I get sound and Video in HD. But when I try to hook this same device to my Sony STR-DG800 receiver using the DVD HDMI input plug (or the other HDMI input), I get nothing... no sound or video. I've tried everything, and it just seems that the HDMI is broken on this device. Does anyone else have a similar experience or have suggestions for how to fix it?
  • mleblanc Dec 31, 2008
    Sounds simple. But what specs would I research to prove/disprove this? I tried 480p, 720p and 1080i. I tried using Pscan and EVERY other setting possible on teh DVD player. It played right away on my LG TV. Do you have any suggestions for what features or settings on either device could be causing the problem?
  • mleblanc Jan 05, 2009
    Someone suggested that the Toshiba DVD player and my Sony receiver may not be compatible.
    Sounds simple. But what specs would I research to prove/disprove this? I tried 480p, 720p and 1080i. I tried using Pscan and EVERY other setting possible on the DVD player. It played right away on my LG TV. I would need another suggestion for how to test compatibility.
    Can someone else please try to help me solve my problem?
    Scholar:
  • 97 Answers
I dont have the exact model you do, but on my sony receiver I have to enter the setup menu and define where the input is for the device I am using. For example I have to tell the receiver to use the optical audio input instead of the RCA Stereo. Otherwise its on default.
Also, you do know this model of reciever offers only pass-through audio on HDMI? that means no surround sound!!! Thats really silly but thats the specs for this model. To get surround you'll have to use optical. otherwise , with HDMI through this sony you are adding an extra component to tyour system with no benefit other than maybe power amplification.
Posted on Jan 05, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! After a Little more Research-These units are not Compatible with Each Other.
  • 142 Answers
The sony device may not be able to support the Toshiba. Make sure that is completely compatible and that you have the correct cables and setting to support everything.
Posted on Dec 31, 2008
6ya staff
SOURCE:
I have a Sony STR-DA5200ES amplifier hooked into a sound system and a 52" Samsung LCD TV. The system is set up to operate on HDMI. The problem that has started recently is that the amplifier polls between...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings.
or
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The HDMI on the Sony STR-DA5200ES does not pass the audio. You need to either connect an optical or digital cable from your audio source. If it is a cable box or DVD player there should be audio outputs in addition to HDM.
Hope this will help...
May 25, 2010 | Sony STR-DA5200ES Receiver
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
No digital audo from dvdld in
That's probably just for the video.  Plug in the L & R RCA plugs for the sound or just use an HDMI cable between your receiver and DVD player.  HDMI cables handle everything in one convenient cable.
Oct 25, 2009 | Sony STR-DE575 Receiver
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Can't get Playstation3 sound through the STR-DG800 using HMDI.
Do you have your ps3 connected to the TV with HDMI and then audo cables from the TV to the receiver? If so, you need to make sure you change the audio settings on your TV to surround sound.
May 12, 2009 | Sony STR-DG800 Receiver
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Sony receiver
change yellow cable and try.
Aug 01, 2008 | Sony STR-DG800 Receiver
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Sound Problems
are u runing dvd player to tv 1st audio and video and eco meens tv is on with sterio same time erther one or other run the the dvd audio to dvd in on sterio and video cables to tv only dont use souind on tv just sterios if u want tv sound tooo use tvs rca outs back into sterio on a ch tv in ok
Jan 24, 2008 | Sony STR-DG800 Receiver
No picture, but sound
I had the same problem and I managed to solve it. It was because the HDMI was set to 1080i and my TV isn't HD. Default HDMI is 480p. You can check your current HDMI setting on the front panel of your DVD. There should be a button with the words "HDMI select". Next to it there should be 3 values. If the current one (a green light shows which one is selected) is not 480p, change it. To change it, make sure your sd-5000 is on, but not reading a DVD. The press the "HDMI select" button on the front panel until the selected one is 480p. This worked for me.
(I had the same same problem without the reading slowly part. On one TV, the sound and video weren't working, and only the video wasn't working on another TV)
Hope it helps.
Dec 28, 2007 | Toshiba SD-5000
Sony STR-DG800 Receiver Logo
589 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
