Self diagnostics function. From the remote I press the power button to switch the TV on. The green led light flashes once, then I get a red led which flashes 3 times repeatedly. What is the issue?
Over Voltage Protection . this is the cause for 3 blinks you see by its stanby/power LED. Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" option, which can be selected from the drop down box
menu by the [Sidebar] tag, at the top left corner of the display
window. It will make search easy. There
are more than 1000 posts to different brand TVs now. Pull up older posts there.
Testimonial: "Not really sure what happened, but the blinking LED has stopped without doing anything. Thanks for your assistance. "
SOURCE: TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Tevion
TV66SIL
065
Tevion
1530, 3731VT, MD3731VT
696
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
* If this works try the other TV functions.
* If these work then the correct code has been selected.
* It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK.
132 244 191 502 100
Please note:
In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press TV followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
037 065 246 399 263 064 446 609 275 077 515 244 398 239 400 459 191 383 607
696
705
742
471
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
If all functions do not work correctly, then repeat steps 1 to 3 and work through all the relevant 3 digit numbers from the Sky Plus remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
OK.
533 038 039 064 102 130 505
679
505
5* Point the Sky+ remote control at the TV and try the volume button.
OK.
563 582 515 098 584 219 104 233 223 065 471
246 399 461 609
OK.
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
1*Select any channel on the TV.
2*Point your Sky+ remote control away from the TV and press the tv button.
3*Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
5. Point the Sky+ remote control at the TV and try the volume button. If this works try the other TV functions.
Please note:- in der to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
More information about my flashing light issue. I turned off and unplugged the TV, left it for a while, but when I turned the TV back on, still no joy. The green 'power on' light flashed twice followed by the red light flashing 3 times repeatedly. After pressing the power button a few times the TV will work as normal. Can anyone help??? Please!
