Hi had this tv for a while now but turned it on last week and half the screen is what looks like white haze other half is fine i can still see everything on the screen also it started to switch off by its self after about a hour or so but switches back on no problem any one have any idea what this might be thanks in advance
Hello... The T CON board might be the problem. All T CONs use one half of the circuit to drive one half of the screen, and the other half to drive the other half of the screen. I have seen TVs with the whole screen "white-washed", and the T CON was bad. Of course, there is a possibility that the LCD panel is bad. T CONs are usually inexpensive, so it's worth trying. I hope this helps!
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
SOURCE: Pioneer PRO-510HD Elite
since your tv is 6yrs old it could be that the video circuit has cold solder that needs to be resolder if that does not work then a focus on the video circuit by replacing the component there, it could be an ic or transistors or diode.if you are not a tech get one to look at your set.good luck.for further help email me at [email protected]
sorry this is a lcd tv not a rear projection
