iLO 3200 32 in. LCD Television Logo
Anonymous Posted on Oct 12, 2012
Where can i get a replacement scramatic
Wiring scramatics for my ilo 32jn flat screen tv "
5 Related Answers
Anonymous
  • 145 Answers
  • Posted on Feb 24, 2008
SOURCE: tv wont turn on
Hello, I am sorry to hear of your problem here. From the sounds of it, this unit will have to be serviced. You say the TV used to come out of standby on its own, normally when the unit is in standby it simply routes power around the Televisions main circuits. It seems that a faulty diode/resistor/selenoid may have been causing this. This is more commen to see in homes with poor wiring and having little or no protections from voltage variations, i.e. blackouts/lightning. It would seem that now whatever was causing the first issue is or is somehow related to the current issue. If you are experienced in electrical repairs you could remove the back cover and check the power supply area for blown fuses and also see if there any heat scars anywhere on the board. If there is a faulty diode/resistor there may be signs.
Anonymous
  • 10 Answers
  • Posted on Jan 01, 2009
SOURCE: cant find a remot
you may purchase a universal remote, (note , be sure it has setup & menu compatability for your particular brand ) or you may purchace a new or used original remote at www.remotes.com by entering your specific brands model number in the sites search field. hope this solves your problem in the most efficient manner!
Jason Morris
  • 362 Answers
  • Posted on Jan 12, 2009
SOURCE: ILO FLAT SCREEN REMOTE CODE
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment. Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Anonymous
  • Posted on Feb 23, 2009
SOURCE: power cord
Please visit www.cordsets.biz or www.fuyuele.com to confirm what you need.
Jaime Hernandez
  • 2351 Answers
  • Posted on Aug 18, 2009
SOURCE: model number LCT27HA36..will not turn on????
This TV is using a power supply MLT168A that has defective capacitors. Replacing the capacitors might fix it, but in some cases the failure is more then capacitors.
Write to [email protected] if you required further assistance.
My 32 inch ilo sd tv is frozen on the now scanning screen I have unplugged it and it won't reset any suggestions ?
old school TV
if it isnt flat batteries in the remote
or desk top set problem
replace the TV
Dont have remote and "ilo"
Sonce iLO TV may be made by FUNAI or AKAI, try those two brands on the lists. You should try to get the original remote to get full fuctions. Only $20
http://www.remotecontrolscenter.com/ilo/rc-370.html
I need to change my Ilo tv from "Digital" to
This is done in the menu through cable or air
1helpful
Who manufactures the iLo flat screen tv
Its usually comprised from different manufacturers for the panel such as Samsung, LG or possibly Chinese manufacturers. ILO just purchases parts and assembles a TV with mixed supplies. Please take a few moments to rate my answer. Thank you.
ILO 26HD
The ilo tv 26HD turns off by its self after about 20 min. of being on.
ILO 32 lcd
It is not cost prohibitive to repair time for a new TV I am afraid I can not give you an exact quote but a 32' Philips screen is 1100 dollars. Thats 200 more than I paid for the TV
ILO 42 inch flat screen tv
can a 42 inch flat screen be replaced my son threw apple and it hit the screen
ILO 32"' TV as white lins across top
my ilo-2600 has lines across the top of the screen.
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
