I cannot eject a dvd, the word 'LOCK' is appearing on the display. Nobody's pressed anything, and there is nothing in the manual about this. The system is about 5 years old. Any suggestions?
I found the solution for my DVD player you need to hold source down for 5 seconds which will unlock the disc.
Make sure the dvd is not in standby then hold source down for about 5 seconds, the message un-lock will appear and your done!
Try unpluging unit and pressing play at same time for 25 seconds that should reset it back so you can get dvd back then you need to cleen the lens because that is what made it do that in the first place good luck
I had inserted a dvd disc in jvc and i pressed play button but it displayed tray errorr what can i do know
tried un pluuging and holding play - also tried initial then volume up then down sequence - any more suggestions for LOCK on screen
I have the same problem have tried the holding down play and unplugging but doesn't seem to work?
