Hi error code appears in freezer and makes beeping sound. what's wrong? please help! thanks
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
Everest staplizer h1 ac not on
I appreciate your post, Sharon!
From the information you have provided your Frigidaire side by side refrigerator is displaying an "H1" error code. I was unable to locate that error code but I did find the error code "HI" which stands for high temperature inside of your freezer compartment. Check your freezer is it still cooling? If so it may just be a miscommunication within your refrigerator and you can clear that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator is providing a "H1" error code. However, "H1" is an invalid code. I show a code for "HI" and that stands for high temperature in the freezer compartment. If you are receiving this error code but your temperature is cold inside your freezer it could be a miscommunication within the board and I would perform a reset on your appliance by flipping the household circuit breaker for ten minutes. I hope this helps. -Matt
error code H1 hi error code appears in freezer and makes beeping sound.
i would call Downing & Sons (337) 537-8903 or Dependable Appliance (318) 445-2780 both are fast and knowledgeable
