Read title
Your problem is the tub seal has failed and will need to be replaced.
Here is a link to the kit you will need.
SOURCE: AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
SOURCE: washing machine problem...
Stop drill the crack then apply some jb weld.Make sure and clean area real good before applying jb weld.
SOURCE: leaking water from bottom of tub
this is bad it needs a center seal/bearing kit this is qite common in the Amana / Maytag line.they are kinda hard to install you may need a service tech to do this for you the kit runs around 80.00 dollars and has instructions. if you need more help you can email me at [email protected]
SOURCE: Amana Distinction leaks
this is a very common probelm with AM washer you have a bad upper sping bearing and at this point you need to cut your loses and send this one to the washer graveyard because this repair in labor intense
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
SOURCE: Amana LW7503 washer is leaking water out the bottom
sounds like a faulty hub andseal kit , heres the part number R9900552 just about a hundred bucks. the only thingnot included int he kit is a 3m sealant( water tight and always flexible), as well as a "SPANNER wrench to remove the center hub. as a technician i get 375 for the job, ifyou wantto attemp it does come with complete instructions as to how to install, but this one id reccomend a pro(sorry but hate to have oyu spend themoney and time yourself, and wind up breaking something else
