Question about MagLite Mag-Lite& Flashlight
Mini Maglite _ Can't open battery housing to change batteries
I have a two AA cell mini maglite. The battery housing is at the end of the maglite opposite of the lamp end. The end cap will not unscrew so I can replace the dead batteries. Any tips on how to remove the end cap? We tried running under hot water and spraying on WD-40 with no success.
  • 6 more comments
  • Anonymous May 19, 2009
    Não consigo remover a tampa para substituir as baterias. O que faço? A minha lanterna é a MINIMAGLITE PRETA
  • Anonymous May 26, 2009
    Useless, tried all kinds of tools. The Mag company suggests leakage and will allow you to return your product.
  • Gene Park
    Gene Park Dec 22, 2013
    The bottom end is a cap. If it has a hole for a lanyard, stick a fork tine through the hole and gently turn. It may take half a turn then remove using fingers.
  • Gene Park
    At the bottom end is cap with a hole for a lanyard. Insert a steel fork tine and gently twist. This should break the seal and then remove the cap with fingers.
  • Anonymous Jan 04, 2017
    Useless, I even used two pipe wrenches and couldn't get the end cap off, ended up throwing it away.
  • Anonymous Apr 10, 2017
    Battery will have swelled and corroded, probably wouldn't have worked anyway.
  • nicholas melton
    nicholas melton Jan 10, 2019
    have you tried using a hair dyer to heat it up and loosen it up enough
  • pomigemes
    pomigemes Oct 13, 2019
    ?I get paid over $426 1 to 2 hours working from home with 2 kids at home. I never thought I'd be able to do it but my best friend earns over $28k a month doing this and she convinced me to try. The potential with this is endless. Heres what I've been doing......
    HERE?  www.more55.com    ???COPY THIS SITE???
If there's a lanyard hole in the cap find something that will fit in that hole for leverage. If not you might have to use some vice grip pliers or two of them. There is a possibility that the batteries have leaked inside the light and has corroded the threads.
Posted on Dec 31, 2008
  • nicholas melton
    what are vice grip plyers
After messing with it for 45 minutes and scratching the heck out of it, my solution was to throw the dang thing away and use the flashlight app on my iphone.
Posted on Nov 04, 2012
  • picasso566
    picasso566 Nov 08, 2012
    I think that's what I'm gonna do thanks!
  • Leslie Thresher
    Leslie Thresher Dec 12, 2016
    Yes! Scratched the hell out of it ruined a good steel fork and royally peed off. Used to love maglites..hate using phone app...I have a black mini mag and the end cap opens like a dream... the newer silver one is friggin fused closed it seems. Never gonna buy one again.
    New Friend:
With all of the views on this problem, you would think that MagLight would
come up with a solution. I personally have had this happen to 2 different
flashlights. Never again will I purchase a Maglight!
Posted on Aug 09, 2012
    New Friend:
I applied a solvent (liquid wrench) overnight, and with a rod in the lanyard hole and vice clamp pliers, was able to remove the cap. But now I'm challenged with removing the corroded batteries so that I can get the battery manufacturer to replace the flashlight....I wish I knew, and had proof of what batteries are in there.
Posted on Jul 27, 2010
    New Friend:
I had luck using dental floss. I slid it between the joints and "flossed it" a bit, then unscrewed!
Posted on Mar 15, 2013
    New Friend:
I was able to open mine without scratching or damaging the case by clamping ordinary pliers, slipped to the wide-mouth setting, and an old leather glove. The pliers didn't cut the glove, and the glove didn't scratch the flashlight.
Posted on Jul 29, 2012
  • Ray Woodcock Jul 29, 2012
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 4 Answers
I was able finally to open the end with two sets of pliars after wrapping it with a rubber cloth to prevent scratching I got it open, but the batteries (at least the top one) was corroded and they wouldn't come out. I poked and prodded around the circular edge to remove a little of the corrosion, but they still wouldn't come out. I boiled a little water, put some in a tall strong glass, only about an inch or two, added baking soda (stirred) and stood the BATTERY END in the water for only about 5 minutes. I then banged it against the side of my counter and both batteries fell out to the floor! I dried the inside, put in two new batteries, put a little vaseline on the screw end threads and everything works great! Yippeee...
Posted on Aug 08, 2017
    New Friend:
I put on WD-40, then used 2 vise grips & tried to twist it open but it wouldn't budge, so I put it through a table vise with cap upside, tightened vise and twisted hand grip to open and it worked. Then I wire brushed the cap and put the flashlight standing upright into a pot of boiling water with a teaspoonful of baking soda in it and left it soaking for 3 hours to dissolve the corrosion inside the battery compartment hoping to loosen the batteries inside. Haven't checked it yet but am hoping it a
Posted on Mar 18, 2015
  • Judi McInnes Aug 09, 2017
    This helped me too. See my post above. Thanks.
    New Friend:
I slipped an allen wrench into the hole for the lanyard and was able to unscrew it fairly easily. It was stuck because the batteries were severely corroded but I've had the thing for six or seven years so that's not a surprise. I should make a note to change the batteries every year or two.
Posted on Dec 14, 2015
6ya staff
SOURCE:
How do I replace batteries on a Mini Maglite AA
unscrew the bottom end, dump out batteries, replace, put cap back on tightly
Jun 23, 2017 | MagLite Camping, Backpacking & Hiking
Tip
How to replace the lamp in a Mini Maglite
The Mini Maglite is a durable, compact flashlight. If your Mini Maglite stopped working, check or replace its two AA batteries first, and if that doesn't fix it, you'll probably need to replace the lamp. You can order replacement lamps in packs of two online, or you may be able to find them locally in a hardware store.
To replace the lamp in a Mini Maglite:
1. Unscrew the bottom of the flashlight. (Hold the flashlight with the head facing down so that the batteries don't fall out.)
2. Remove the batteries.
3. Unscrew the flashlight head from the barrel.
4. The lamp is mounted into the flashlight on two prongs; gently pull up on the lamp to remove it.
5. Install the new lamp by lining the prongs up with the two holes and slowly inserting it fully.
6. Screw the flashlight head back on.
7. Reinsert the batteries.
8. Screw the base back on.
When you've finished, turn the flashlight on (by turning the lens cover or the head counter-clockwise) to verify that the new lamp works. If the light doesn't come on, take the flashlight apart again and check to make sure the lamp is installed correctly and fully. Since the lamps come in packs of two, if you can't get the first lamp to work, try the second lamp in the pack. If that lamp doesn't work either, check your batteries and make sure the lens cover and head are both screwed on all the way.
on Jan 12, 2011 | Kitchen Appliances - Others
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
Cant open battery to change.Mini Maglite
My Mini Mag light has a knurled cap on the end opposite the light bulb. It should unscrew to reveal the AAA batteries.
Jan 16, 2011 | MagLite Mag-Lite& Flashlight
I cannot get the cap off to replace the batteries of my mini maglite 2 cell AA
Probably a leaking battery has coroded the cap. You can send it direct to MagLite for warranty. Go to: http://www.maglite.com/repaircenters.asp
to find the nearest warranty/repair center.
Gary
Nov 14, 2010 | MagLite Mag-Lite& Flashlight
Battery case does not open
make sures its being turned to the left, and if it will not come off, wrap duct tape around it to protect it and use large vice grips or pliers to get it off. Vice grips would be better as the lock but dont' lock them down too tight as you can dent the cap.
Jun 30, 2010 | MagLite Mag-Lite& Flashlight
Is there a rear cap on a mini maglite. I am
Yes there is a cap. I had the same problem most likely the battery inside has corroded and leaked fusing the cap shut, contact MagLite at www.maglite.com if there were either Duracell, Eveready or Ray-O-Vac batteries in there they will replace it for free under warranty.
May 26, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I have an AA Mini Maglite and it quit working. I replaced the two batteries and lamp and still does not work. Any suggestions?
I have several of these flashlights and experienced the same problem. Here's my solution: take off the light end and you will see a black base where the bulb is inserted into. The black base rotates. If all else is functional (batteries, bulbs, etc.), when you rotate this black base, the light should come on. Moving the base back and forth several times seems to help also (it seems there must be some kind of contact problem). All that's left is replacing the light end.
Jun 18, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Don't know how to replace AA batteries in Maglite AA.
they either unscrew from the back end or they unscrew from around the thick light end , then just pop in some new batteries making sure that they are pointed in the same direction
Jun 02, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
MagLite Mag-Lite& Flashlight Logo
48,839 people viewed this question
Top MagLite Electrical Supplies Experts
Paul G
Paul G
Karl Kittsteiner
ray gallant
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
