1. Check your cable
2. check your cable pins make sure there not bent.
3. Check your video card make sure its putting out the correct resolution for the monitor.
No signal is just what it is. You may have a bad cable,bent pin or video card is not operational.
Things you can try.
Hook it up to a diffrent computer
Check the pins on the cable.
Worse case would be the little board inside where the connector is could be bad.
Thanks I hope this helps
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
