Question about ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI (t2-p)
Connecting USB-Serial to Excel VBA
For a normal RS232 port, a VBA program behind Excel can use (or the assigned port). This allows ASCII strign I/O which is what I want to do.
This does not seem to work with the Radio Shack Serial-USB cable. Does anyone have a way to do this?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 17 Answers
You can also use the SysInfoTools Excel VBA Password Recovery Utility.
https://www.sysinfotools.com/recovery/vba-password-recovery.php
With this tool you can:
Supports VBA password recovery from .doc, .xla, .xls, .xlsx files.Supports recovery of multilingual, complex & lengthy passwords.
Supports all versions of MS Office, including 2016,2013,2010 and others. Connecting USB-Serial to Excel VBA - step-1-undefined-undefined-0.jpg
Posted on Jan 08, 2020
    Sergeant:
    Novelist:
  • 326 Answers
Http://support.microsoft.com/kb/832678 just check out this link.
Posted on Jan 11, 2009
    Sniper:
  • 88 Answers
I believe you will need to use an RS232C adapter attached to the end of the Radio Shack Serial-USB cable. This is typically referred to as an RS232 null modem cable. These adapters and cables are available at www.cablestogo.com
Hope this helps, please rate my solution or ask more questions. Thanks.
    Scholar:
  • 160 Answers
U will require and extension converter to do it.get the converter cable to do this.
Anonymous
SOURCE:
Can you tell me the communication setup for the xl200GPS MEADE 8 inch telescope. Like the comm Port number along with the other settings. Thank You.
If you mean the LX200GPS from Meade, http://www.meade.com/manuals/505ccs/index.html#tc gives the following settings for the AutoStar RS-232 Serial Com Port:
Baud Rate: 9600
Data Bits: 8
Parity: None
Stop Bit: 1
Flow Control: None
http://www.meade.com/manuals/autostar/apb.html has the pin assignments for the 4-pin and 6-pin adapters that connect to the RS232 cable.
Most versions of Windows from WIn95 on will automatically assign the serial port an unused IRQ port if you add a add-on card to a PCI or PCIe slot. (USB to serial port adapters should be able to do something similar with the above data.)
I hope this helps.
Sep 12, 2013 | Optics
SysTools VBA Password Remover serial
If you want to remove the VBA password from Excel, Access, Word, PowerPoint and Outlook etc with the help of VBA Password Remover Software rapidly.
http://www.vbapasswordremover.net/
http://www.systoolsgroup.com/vba-password-remover.html
http://www.vbapasswordremover.com/
http://www.vbapasswordremover.org/
May 25, 2011 | Excel-Tool Excel Tool VBA Password...
What is exel sheet extension in office 2010 ?
Excel Workbook
.xlsx
The default Excel file format. Cannot store VBA macro code or Microsoft Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Workbook
.xlsm
Uses the same basic XML format as the Excel Workbook, but can store VBA macro code. Users saving an Excel workbook that has VBA code or Excel 4.0 macro sheets (.xlm files in Excel 4.0) are prompted to use this file format.
Excel Template
.xltx
The default file format for an Excel template. Cannot store VBA macro code or Excel 4.0 macro sheets (.xlm files in Excel 4.0).
Excel Macro-Enabled Template
.xltm
Can contain a VBAProject part or Excel 4.0 macro sheets (.xlm files in Excel 4.0). Workbooks created from this template inherit the VBAProject part or Excel 4.0 macro sheets that exist in the template.
Excel Add-In
.xlam
A supplemental program that runs additional code. Excel add-ins use the Open XML file format to store data, and they support using VBA projects and Excel 4.0 macro sheets.
Feb 21, 2011 | Computers & Internet
Dear sire I have symbol LS2208 handheld scanner (serial cable) but when connected in com port in a regular PC it do not power on .
you're going to either connect it to a com port that provides power, or get a different cable that allows you to connect an external power supply to it.
CBA-R01-S07PAR RS232 Cable assy, 50-14000-009R 220V PS,
or get a usb cable - program the scanner to USB, This will provide the power.
CBA-U01-S07ZAR-B
but only if you have an operating system that recognizes USB
Sep 23, 2010 | Symbol LS2208-7AZK0100S Handheld
I have an Sam4 ER600 which is 9 pin seriel and only USB on my computer. I have got the recommended adaptor and software but my computer still doesn't recognise it... It says port failure. Can someone...
Buy an Athen usb-->Rs232 adaptor and install the program.. then go to hardware settings and set that usb port to Serial port 1 (very important)
After that you just start the program, opens your store @ port 1 and programs..
Jul 27, 2010 | Samsung Computers & Internet
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
Feb 22, 2010 | NEC Lands Phones
Hi I'm Kandy When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6. The software then shuts down. I...
I replaced my USB/Serial RS232 port adapter with a genuine RS232 serial port on the PC. THis solved the problem. Further reasearch on the net indicated that USB to RS232 - serial port converters do often have problems. I previously had not had a problem running on Windows XP and this is what alerted me to the possibility of the USB/RS232 port adapter as a possible reason for the "new" problem.
Oct 24, 2009 | PfaFF Creative 7570
VBA and macros
SLA consultants in India. The training program is intelligently designed by industry experts to provide hands on experience and in-depth knowledge to the participant regarding MA Access database and Visual Basic for application programming. The training will use real time practical sessions and live projects and assignments to offer you a better understanding of both the tools. https://www.slaconsultantsindia.com/vba-macros-programming.aspx
Jun 22, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
USB doesn't work
do have the driver for the IBM? then use it. if you don't, then what about serial port or RS232. get a converter that is serial to usb converter with the driver will allow you to use your usb through serial port.
Apr 07, 2009 | IBM ThinkPad T43 Notebook
Cannot connect denon products to computer
Hello! I presume you are connecting it via the RS232 connection to the PC. This method is NOT plug and play, like a USB connection is, so you will have to install the driver that presumably came with it, then manually assign a port from within Windows. Although I don't have this amp, I have experience in connecting similar devices using the RS232 interface. Also, make sure the BAUD speeds are correct. This is also defined from Windows.
Apr 12, 2007 | Denon AVR-4306 Receiver
ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI (t2-p) Logo
832 people viewed this question
Top ASUS Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
B.Th. Pluijm
B.Th. Pluijm
Lawrence Oravetz
Are you an ASUS Televison and Video Expert? Answer questions, earn points and help others
