Checked drain back to bottom of drum including the ball
Here is a link to the complete service manual. You may need to create an account but you will be able to download it.
SOURCE: Will drain but wont spin
Try these
pls rate my suggestion......
SOURCE: my washer doesnt seem to
Thanks for choosing FixYa and welcome. You do need to check the motor drive. Make sure the belt is not slipping or worn. That could be the case. It may be wearing out as you have suggested. You just need to get to it and determine the cause.
SOURCE: Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
