Question about Car Audio & Video
Lost radio codes
Recently had new battery fitted,now radio will not work. I bought car secondhand with no owners manual. Renault Laguna Sport, year 2000, model 1.8 16valve.
    Scholar:
  • 69 Answers
I don't know if this works on those newer type stereos but years ago people used to put vauxhall stereos in the freezer for 24 or so hours, defrost so there's no water on the circuits or pop the top off & wipe circuits dry, then power it up & the code is not needed any more.
I have done it myself before & it did work but they changed the EPROM chips after that little trick got around as EPROM stands for (Erasable Programable Read Only Memory) & freezing them worked, if that dosent work you could try finding the chip (look's like normal chip but has a white sticker over a glass lens on the top middle of the chip) ultra violet light re-sets some when passed over the chip lens, you could have a laugh & go to your local shop & use their note testing light as that has a UV Ultra Violet tube. anyway joking aside freezing cant hurt & it is a joke having to pay for your own car stereo code if it is legally your car stereo & you can prove it!
Have fun Oh & by the way im not insane just an electronic engineer!!!!
Posted on Mar 26, 2009
Not familar with your car but I had same problem many years ago with a Vauxhall Astra and did same as you, disconnected battery and re-connected, radio didn't work - but my display kept flashing for security code to be re-input, which I didn't have.
Yours could be the same if radio not worked since disconnection - solution: if you dont have code & not in any documentation you got with car, then the radio will need to be re-coded by a dealer (expensive) or enquire with local car spares shops - they normally know a cheaper source. Mine cost about £18 (5 years ago) to get re-coded & I had to remove & reinstall myself.
Posted on Jan 01, 2009
6ya staff
SOURCE:
Free radio code renault laguna 2001
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Renault service centre and get them to enter this code for you.
Oct 07, 2012 | Car Audio & Video
I need a radio code for renault laguna
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Renault servicecentre and get them to enter this code for you.
Aug 02, 2012 | Car Audio & Video
I have recently purchased a renault laguna and the radio code supplied in the handbook does not seem to be correct as it wont work!! serial no: rn278f10072293 tor151 can anyone help?
the code has been changed by the person you bourght off,this can be reset but you'll need to read the manual to do this,or ask the preveuse owner for the code.
or ask them how to reset it :http://www.renault.co.uk/cars/model/newlagunahatch/product.aspx?WT.srch=1
Sep 28, 2010 | Car Audio & Video
Radio Installation procedure
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are the working Code Entry Instructions if the Renault does NOT have the Steering wheel Remote Control
Keep pressing the Preset [1] until the correct first digit appears on the display
Keep pressing the Preset [2] for the correct second digit
Keep pressing the Preset [3] for the correct third digit
Keep pressing the Preset [4] for the correct fourth digit
If the correct code is now shown on screen, press and hold the Preset [6] for 10 seconds to save it.
Note: If Preset [6] does NOT enter the code , then try Preset [5]
Jun 06, 2010 | Car Audio & Video
I had to change my battery on renault laguna and now i need the
you must contact car dealer and , may be give them some proof of ownership.They must give you the code.
Jan 27, 2010 | Car Audio & Video
Renault Laguna radio code number
try instant radio codes dot co dot uk unfortunately this will cost about 15 quid hope this helps
Nov 23, 2008 | 2000 Renault 181
Car radio code
I had a Laguna before the gearbox packed up. Nice car but a really bad gearbox. My radio was the same. What I used to do to get it going again was disconnect the battery and thereby power it down completely. After I reconnected the battery it allowed me to reenter the code as described in the radio manual.
Happy listening, with the radio on you wont hear the gearbox tearing itself to pieces.
Sep 30, 2008 | 1986 Renault Sport
Radio code 2002 renault laguna
You will need to contact your nearest dealers, they (For a small charge) will reset it for you.
Jul 11, 2008 | 2002 Renault Sportwagon
Renault Laguna 2.0 litre 16v Executive - car alarm stopped working
on the index look for fuses and check all the fuses also instead of been looking for alarm look for antitheft system
May 18, 2008 | 1986 Renault Sport
Car Audio & Video Logo
664 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
