Question about Gentex 2002 Mazda MPV - All MPV models - K2 Auto-Dimming Rear View Mirror
Please help me to locate Engine Code on Engine Block for Mazda MPV 2002 2500cc.
    New Friend:
  • 21 Answers
The engine code is located beneath the oil filter The vin number will be located beneath the windscreen drivers side
Posted on Oct 15, 2012
  • Raden Zen
    Raden Zen Oct 18, 2012
    Thank you very much Kris, Very helpfull to me and I found it
Anonymous
SOURCE:
How do i locate the engine number of mazda mpv
Engine Number
Generally found on the front nearside of the engine block!
Oct 02, 2014 | 2002 Mazda MPV
Where is thermostat located in a 1994 Mazda mpv
It appears to be under the thermostat housing if you follow the radiator hose to the block. b2a7a5d2-8adb-418b-a943-969711898ddc.jpg 098ff7c2-8b47-48fd-b850-1643d1a31dac.jpg
May 07, 2014 | 1989 - 1994 Mazda MPV Engine Coolant...
I need to know where the Engine Number for Mazda MPV 2002 2500cc
The 8th Digit on your VIN # is a Letter
That is your ENGINE CODE seldom go looking
on engine block for casting #'s
It is on your dash by windshield ,registration & insurance card
The code only tells you what you already know
What displacement your motor is
Oct 10, 2012 | 2002 Mazda MPV
Where can i find the engine number embossed on the engine block of Mazda MPV 2000 model?\r\n
mazda mpv 2000 model
tell me the cc of the mpv is it 2000 cc or 2500 cc
Oct 24, 2010 | 2000 Mazda MPV
Need to know location of fuel pump relay on a Mazda mpv 3.0l v6 1997 model
The fuel pump relay is located below the right side of the dash to the left of the engine control module. There is also a 15amp fuse
for the fuel pump. In the fuse block under the left side of the dash
fuse #19. Hope this helps.
Mar 18, 2010 | 1997 Mazda MPV
Timing marks on 1993 mazda mpv
They are on the outside edge of each cylinder head.
Aug 19, 2009 | 1993 Mazda MPV
2004 mazda MPv Where is the location of cyl. #6?
The firing order is 1-4-2-5-3-6. The cylinders are, front bank is from drivers side to passenger, 6-5-4 , and 3-2-1 at the firewall.
Jun 08, 2009 | 2004 Mazda MPV
Alternator not charging the battery.. Do you know where the alter
You own a mini van. These creations were designed by engineers to drive mechanics crazy! :-( Everything is designed with little or no access. The alternator on your van is made of aluminum (so it's silver). It is located near the crankshaft harmonic balancer. If you look at the harmonic balancer, the alternator will be at the 10 o'clock position. It is on the passenger side of the engine, behind the engine block. One of the fan belts goes to it. The pulley on the alternator has a belt on it. Follow the fan belt which goes towards the rear of the engine.
Charlie
PS You may have to get under the van to remove it.
Nov 16, 2008 | 1989 Mazda MPV
Gentex 2002 Mazda MPV - All MPV models - K2 Auto-Dimming Rear View Mirror Logo
254 people viewed this question
Top Gentex Optics Experts
Lawrence Oravetz
bobalix
ray gallant
Are you a Gentex Optic Expert? Answer questions, earn points and help others
