Gets stuck most times just at end of wash cycle...not sure if its a call out job or not
SOURCE: bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display.
This is apparently a failure to drain properly.
I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains.
Turn off the water supply to the machine.
Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water)
Remove the drain hose from where you have it going to.
Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water).
Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum.
Use some pliers to pinch the steel spring that clamps the hose in place and remove.
Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on.
Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks).
Plug it in, turn on and that for me was it.
Job Done.
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Your pump/filter is plugged. (E4) There
is a round door on the lower front of the washer. There is a small hole near
the door. Put a small screwdriver blade in the hole, push in just a little, and
you can rotate the door clockwise, the door will come out and you can get to
the problem. When the water is drained
in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter.
When you unscrew this, all the water left in the washer will spill out onto the
floor. Use a plastic bag to catch this or a small pan.(later models have a
drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find
the source of your clog. Remove it, clean out, screw the black connector back
in. You can check with rinse, if you
want to make sure there are no leaks. Put
the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
