I am trying to connect my zenith video thru my onkyo tx-sr706. I am getting no signal on the tv when I use a hdmi to dvi cable from the onkyo.
SOURCE: HDMI from laptop to DVI plug on Hitachi big screen TV
To fix it, just turn the set off, let it discharge for a few hours. Reach in and remove the socket from the back of the tube and reinsert a few times to break through the corrosion.
This is a sign of weakness in the manufacturer of the guns and the connecting sockets. The metal used in the pin connections inside the socket are corroding and when you remove the socket and reinsert it cuts through the corrosion and makes good
contact again.
If still not working contact the support for your television..
Hope that helps......
SOURCE: HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
SOURCE: samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
SOURCE: Connecting Magnavox NB500MG9 Blu-ray player
could be the hdmi is shot. try unpluuging the unit from the wall for a few hours and try again
