Check whether the TV is in Mute Mode.. Also check whether you've connected anything to the Audio output of the TV. like headphone or an external speaker...
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
First check all input cables, make sure all cables are good & plugged in fully. then check with a DVD player to all HDMI & component inputs. if none of this solves issue you may need MAIN PCB.
PT# 934C335007 $139.99
http://www.tvpartsguy.com/servlet/Categories
If the rear inputs work consider connection for the channels with a box using one of the rear inputs--sounds like a tuner related issue and going to the rear inputs bypasses that.
It is a new tv.Take it back where u bought it and trade it in for another tv.This tv have those 2 LCD long inverter boards have problems.These 2 long LCD inverter boards are to help the tv LCD screen panel to have a backlight for the tv LCD screen to produced a picture.
thanks very much about your technical support.but i solve allready the problem of LG LCD TV MODEL LT-15A10 TROUBLE; no picture with sound, i replace the socketed ic SDA555XFL62 PINS. THANKS... LODIVAR.
Is the "Mute" function turned on?
