SOURCE: Removal instructions for close caption
If you are hooked up to a cable receiver, the closed caption must be disabled in the cable receiver. With most cable receivers the closed caption must either be on or off and there is not cc button on the remote.
SOURCE: CLOSED CAPTION
Unplug the TV, let it sit for a few minutes, then plug t i again. That should reset it. If not, you'll probably have to order the remote from the company to turn it iff.
SOURCE: cant turn off closed captioning
I have a PME-42S6 on Ebay that has a turning on problem it is a complete unit and work good if you can get it to turn on
Ebay # 120362175465
bid on it and pick it up and there is your remote control
Bob
678-333-6746
SOURCE: Closed caption cut off
Look for a button that says "aspect ratio" . or you may have to go into the menu.
SOURCE: my closed captioning is getting cut off
Are you changing the format or picture size. Some times marked zoom on the remote. Are you using a cable box or SAT recever. These boxes also have setting for format change.
